NGK Iridium spark plugs
Old Apr 23, 2014 | 03:25 PM
graham11's Avatar
Default NGK Iridium spark plugs
hi guys ,
enyone got or tried these plugs in there xk,
just wondering if there worth the extra money and there as good as thay make out to be,
uk price range between £70/£120 for set of 8.
Old Apr 23, 2014 | 03:49 PM
K.Westra's Avatar
Mine had NGK iridiums in and at 82000 miles they were pretty well worn. They didn't make 100k but certainly not bad. I put in Bosch iridiums.
Old Apr 23, 2014 | 06:39 PM
Beav's Avatar
NGK Iridium are very good plugs, they are the next step up from double platinum and considered top-tier. $6.44 USD/ea. @ RockAuto.com . Don't waste your money on any plug with multiple electrodes, they just shroud the spark.
Sorry, but when I used to work next to a state emission inspection station (and saw just about everything that wouldn't pass the test) I yanked and pitched more Bosch plugs than any other brand. Local A-zones used to push them like the next coming. Personally, I'd stick with NGK or Denso.
Old Apr 24, 2014 | 01:56 AM
JagV8's Avatar
I had them (NGK iridiums) in my STR (4.2 V8) and changed at 100K for more. They weren't apparently worn even at 100K so if the new last the same and the car's still running I'll be very very happy!
Old Apr 24, 2014 | 07:40 AM
Jon89's Avatar
Denso and NGK are both excellent iridium plug choices. I've had two different sets of Denso iridium plugs do more than 130,000 miles in two different Lexus SUVs and still look and perform like new....
Old Apr 24, 2014 | 08:00 AM
Fulton's Avatar
Last weekend I put in a set of NGK iridium plugs in mine replacing the Bosch platinum plugs. immediately noticed a smoother idle and quicker response. Worth it for me but I only paid $7.50 CAN each. My wife and I are planning a trip to the UK in 2015 should I plan on packing a bag of parts for you guys?
Old Apr 24, 2014 | 09:34 AM
graham11's Avatar
thanks guys thats good enough for me,i will stick some in this weekend and keep you updated.
Old Apr 24, 2014 | 05:34 PM
BurgXK8's Avatar
I went with Bosch Iridium plugs too; probably much of a muchness compared to the NGKs but a personal preference. Either one should last you a while.
Old Apr 24, 2014 | 05:42 PM
Beav's Avatar
Be aware that you never, ever use a plug gapping tool or feeler gauges to check the gap of an iridium or platinum spark plug! The precious metals are extremely thin and dragging any gauge through the electrodes will scuff and/or remove at least a portion of the coating. That would relegate the plug to base plug status. The plugs are application specific and don't require checking. Just eyeball the gaps and if you find any that look different than the majority return it for another plug.
Old Apr 25, 2014 | 07:45 AM
Jon89's Avatar
Agreed - iridium plugs should be good to go right out of the box....
Old Apr 25, 2014 | 10:57 AM
giandanielxk8's Avatar
Does pep boys carry NGK iridium plugs?
Old Apr 25, 2014 | 01:23 PM
White Bear's Avatar
Old Apr 25, 2014 | 01:57 PM
SNG Barratt USA's Avatar
Former Sponsor
We do! $20.51 a piece minus your 10% discount.. (ngk oem iridium's)
Old Apr 26, 2014 | 12:49 PM
1avguy's Avatar
I just replaced a set of NGK iridium plugs with same kind from local Jag dealer (they were same price as on line) in my 03 XK8 at 93K miles. I have been trying to track down a ping and a rattle. They did not show any appreciable wear and had ideal color. Performance did pick up and idle smoothed out. Not the answer to the ping but seem to be good plugs.
After that, still trying to eliminate ping occurring on light acceleration, I did treat the beast to a 50/50 mix of premium and 100 octane racing fuel. Lot's of get up and go and great mileage boost - not to be mistaken for an economy move but still fun.
Old Apr 26, 2014 | 01:59 PM
worrasf's Avatar
Just pulled the work sheet from the dealer. Fitted the following plugs: C2A 1535
to my 2001 XKR 4.0L at 68,000 miles. Only done 73,000 so no need to change. Looking on the web these plugs are Iridium Spark Plug - C2A1535 - Genuine Jaguar at www.rimmerbros.co.uk.
They had previously fitted AJ8 4575 plugs at 43,000 (so a 30K interval) - these also show up as Iridium so I am guessing likely same plugs with updated part numbers
I presume no great difference with NGK or Denso. Likely made by them anyway and rebadged.
Steve
Justinb
E type ( XK-E )
Jun 21, 2023 05:29 PM
Poet
Oct 2, 2015 09:00 AM
42Ajd
Sep 26, 2015 07:04 PM
reb1999
Sep 26, 2015 08:41 AM
Pristine97XK8Convertible
Sep 10, 2015 09:24 AM
