No-start due to Neutral Safety Switch
Old Mar 22, 2010 | 12:18 PM
H20boy's Avatar
Default No-start due to Neutral Safety Switch
What I thought was a weak battery, my mechanic is now thinking my no-start in Park is being caused by a failing Neutral Safety Switch, a $500 part! (whole gear selector is replaced)
It started two weeks ago after a week at the airport garage, it didn't want to start. Gauges would light, radio would start with the nav, everything...just no cranking at all. Thought at this point, it was a weak battery.
Moved it to Neutral, then back to park, and it started.
Fast forward to a few days ago. Sat overnight, tried to start in the AM, no cranking again. Moving to P-N-P-N finally turned over in neutral.
Today, stopped by to pick up something, turned off the car. Returned, no-crank again, this time P-N-P-N-P-N-P-N-P-N-P-N...finally cranked.
I was told that it will eventually not let me start no matter how often I exercise it.
Mechanic thinks that by parking on an incline (which I only do at work) w/o using the parking brake will put stress on the switch when taking it out of park. I suppose it makes sense, and I do not use the parking brake at all. (I did today though, crossing fingers)
I won't be able to bring it back to the shop until next week. In the meantime, any other thoughts? Is this 'adjustable' or am I buggered, as the Brits would say.
Old Mar 22, 2010 | 01:14 PM
Gus's Avatar
Gus
Well you are # 3 on my list of no starts because of a “P” & “N” selector switch. I want to know more about this switch. Is it internal or external? The one I found is external and I want to get my hands on one so I can see if it is repairable.
Matt – After you talked so nice to her. Now you know why I talk to mine that way!
Old Mar 22, 2010 | 01:16 PM
H20boy's Avatar
^ I know, I know.
They showed me a gearshift removed from an s-type, and the part he was referencing was inside, under the gear selector part.
If I do replace mine, I'll save my part for you Gus.
Old Mar 22, 2010 | 01:22 PM
Gus's Avatar
Gus
Originally Posted by h20boy
^ I know, I know.
Yes Please! It sounds like another mystery that is going to bite us all. I do understand used ones are available.
Old Mar 22, 2010 | 02:39 PM
jnporcello's Avatar
I haven't tried it yet, or needed to luckily, but I seem to remember when buying my '98 XK8 the dealer told me that they had a problem with those switches. There is that star shaped nut on the upper left part (I think) of the gear surround. He said if it ever wouldn't start to remove that star shaped thing, and put something thing in there to depress the switch, that bypasses the safety switch. Like I said, never tried it, but may be worth a try.
Old Mar 22, 2010 | 08:08 PM
Gus's Avatar
Gus
I think this is the switch we are looking for.
Attached Thumbnails No-start due to Neutral Safety Switch-transswitch2.jpg   No-start due to Neutral Safety Switch-transswitch.jpg
Old Mar 23, 2010 | 11:51 AM
H20boy's Avatar
Maybe the 6P ZF isn't mounted to the transmission? Every other swtich i've seen has been.
I can't even find it in the parts list.
Old Mar 23, 2010 | 12:11 PM
Gus's Avatar
Gus
I found this to be a great resource;
http://openpdf.com/
http://openpdf.com/ebook/zf-5hp-24-pdf.html
Old Mar 25, 2010 | 11:43 AM
H20boy's Avatar
Switch hasn't acted up again since the other day, waiting as long as possilble before I spend $700 for the swap-out. If my status changes, I'll update the thread...promise.
Old Mar 25, 2010 | 11:53 AM
Gus's Avatar
Gus
No used ones laying around?
dsnyder586
Dec 29, 2024 07:39 PM
Vector
US Lower Atlantic
Sep 13, 2015 03:01 PM
Wolfy
Sep 11, 2015 06:27 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
