OBD reader for 97 XK8 UK spec
Old Apr 28, 2021 | 03:56 AM
Pistnbroke's Avatar
Default OBD reader for 97 XK8 UK spec
I read about people with multiple non working code readers so can someone advise on one for the above vehicle preferably one that connects to a laptop. What is the protocol its clearly not a standard OBD 2.
thanks in advance
Old Apr 28, 2021 | 04:09 AM
laguillotine's Avatar
I have tried a few on my 97 XK8 but found that anything that was compatible with Modern Jags, basically everything on the market, would not work with mine (despite saying they would with Jags from 95/96) So I ended up buying and old XP laptop and a Mangoose lead with the old Jag software, once I got softwear installed it worked perfectly.
Old Apr 28, 2021 | 04:32 AM
Robin Smith's Avatar
I have a similar issue with my 1998 XK8. I'm guessing that the introduction of the the AJ27 engine improved the OBD functionality.
Where did you get the cable and Jag sw? I've got an xp laptop.
Old Apr 28, 2021 | 04:34 AM
Pistnbroke's Avatar
found the mangoose lead ,seems to come with software or link to .....great job ..now to find the old laptop!
Old Apr 28, 2021 | 05:07 AM
Pistnbroke's Avatar
Just googled Mangoose lead and got three suppliers
Old Apr 29, 2021 | 01:39 AM
CA Jag's Avatar
I couldn't get codes using 2 different standard readers (that powered up). shop used Jag SSD and had no problem finding defective ABS module (which caused CAN problems).
If you're having code problems, a laptop and software seems like a better approach.
Old Apr 29, 2021 | 02:09 AM
Pistnbroke's Avatar
Just got to get the old laptop going in XP then get a mongoose . Prior preparation prevents **** poor performance ....the 7 ps again ( just count the words)
Old Apr 29, 2021 | 03:18 AM
Stephjac's Avatar
Default IDS and VCM
I bought an original ford rotunda VCM, they are usually 375.00-525.00 USD in the US, then I found a Panasonic toughbook from 2003 to run IDS on. Jaguar is using a few different protocols in 1997 for different systems. OBDII is mainly fir emissions reporting, so generic DTC, any real action is going to be happening through IDS, which will give you the ability to communicate with systems such as ABS, ECM,BPM, and TCM, programming of modules, etc. The original Drew Technologies Mongoose are out of production, so most that you see are Chinese clones of varying quality, same with counterfeit VCM, so you can read with most of them, for about a 12 months, you can’t safely program with them, at least not the ECM, because the fakes can’t buffer properly and will crash with some modules, bricking them. I’ve seen great deals on VCM1 on UK eBay, there’s basically the red ford version, the blue jaguar version, and a Mazda version, which are supposedly all internally identical. The software will flash the VCM for jaguar use automatically. I’ve never used the mongoose, since a real one is only 100 usd less than a factory VCM and harder to find in the US. If you just want to read generic codes a ‘blue driver’ and an iPhone also works for quickie scans on my 1997 for about 105.00 USD, but is inconsistent lately, but also scans my 1998 Land Rover.
Old Apr 29, 2021 | 03:44 AM
Pistnbroke's Avatar
Old May 2, 2021 | 03:32 AM
Pistnbroke's Avatar
Old Jun 23, 2022 | 09:34 AM
St. Stephen's Avatar
What is the "old Jag software" you are refering to please? I have an old laptop running on XP so if I can just use this laptop without the need for an expensive OBD2 reader how do I go about it?
cheers.
Old Jun 23, 2022 | 09:37 AM
cheers.
Old Jun 24, 2022 | 01:02 AM
Pistnbroke's Avatar
I have moved on from my original thoughts on fault code readers ...the older jags 96/97 have more limited readability but you can get the old factory software on ebay. I have gone to the i 930 from icarsoft
laguillotine
Jul 21, 2017 11:08 AM
Orthodixie
Jun 5, 2017 11:55 AM
vandenplas408
Apr 30, 2017 01:12 AM
cyber3d
Jul 3, 2015 12:22 AM
