Obd troubleshooting
Old Jun 13, 2015 | 11:35 AM
Ettengerg's Avatar
Default Obd troubleshooting
My scanner will not communicate on the serial k line. It does read on the the other networks. The wiring diagrams show ecu, accm, Ktm, and damper control. I do not have a Ktm or damper control. I read -11.53 v on pin 7 to ground. If I disconnect ecu I get -10.02v. With accm disconnected -11.31v. I disconnected batt. Pin 7 to gnd 39 ohms. Accm disconnected ecu to gnd 50 ohms. Ecu disconnected accm to gnd reads 193 ohms. Since ecu and accm are in parallel the resistance checks out. I tested the cable and no ground faults. I looked at both ecu and accm modules did not see any issues with traces or caps. Any ideas on why I am not getting comes?
Old Jun 13, 2015 | 02:49 PM
JagV8's Avatar
Bad OBD tool, most likely.
Old Jun 13, 2015 | 03:48 PM
Ettengerg's Avatar
Tested the scanner on another car and it worked fine.
Old Jun 13, 2015 | 04:22 PM
Jaguars are fussy about scantools as you'll see from this thread in General Tech Help:
https://www.jaguarforums.com/forum/g...-%2A%2A-33347/
Old Jun 13, 2015 | 05:22 PM
Ettengerg's Avatar
I am able to read can and s&p networks and have used two scan tools specific girl jaguar. I should be reading about 5 volts in pin 7 not 11v.
Old Jun 13, 2015 | 09:43 PM
WhiteXKR's Avatar
Try connecting pin 15 to pin 7...this is necessary when pin 15 from the reader does not connect the required wake-up signal needed on earlier vintage Jaguar OBDII interfaces.
Old Jun 14, 2015 | 06:51 AM
JagV8's Avatar
I think you have the wrong idea of the correct voltage. Typical for ISO9141 is about 10.7V I think you'll find. It is a task of the testing device to pull the pin up to batt+ via 510 ohm resistor as I recall.
Old Jun 15, 2015 | 03:44 PM
Ettengerg's Avatar
Thank you for your sage advice! I jumpered pin 7 & 15 and I was able to read the codes. V8 ur right also the pin is around 10v then drops to 5v. Again thanks for the help.
carl purchase
Oct 14, 2015 06:14 PM
10 XF Premium
Oct 2, 2015 09:22 PM
millertic
Sep 30, 2015 08:11 PM
foxbottom
Sep 25, 2015 03:24 PM
