Oil pan gasket question
Old Apr 29, 2016 | 05:17 PM
mbates50's Avatar
Default Oil pan gasket question
My XK8 is 10 years old and mechanic is saying I need to replace the oil pan gasket. (It's leaking).
Question: Is this normal for a 10 year Jag?.
Don't believe I've ever had to do this in the past with a non-Jag car.
Old Apr 29, 2016 | 06:58 PM
RJ237's Avatar
It's always possible, but uncommon. Cam cover leak is more common, but even that is not a routine issue.
Old Apr 29, 2016 | 07:23 PM
NBCat's Avatar
Don't believe I've ever had to do this in the past with a non-Jag car. Thanks
Hopefully the area was thoroughly cleaned and inspected for any other possibilities such as the cam cover gasket as mentioned above.
There are other brands that have engine sump leaks quite regularly, such as the GM Northstar unit. The AJ-V6 seems more prone to this than the AJ-V8.
Old Apr 30, 2016 | 01:37 PM
..... Question: Is this normal for a 10 year Jag? ......
1. NO - it's not normal
BUT
2. if it's leaking then it doesn't matter if it's the only one in all 90,616 XK8/XKR's produced, it needs to be replaced.
Old Apr 30, 2016 | 01:57 PM
flatsix's Avatar
i guess he was talking about the gearbox oil pan. if so, make sure that it is actually the pan gasket and the not the commonly leaking o-ring of the plug adapter of the controller harness.
fritz
Old Apr 30, 2016 | 05:21 PM
mbates50's Avatar
Old Apr 30, 2016 | 05:22 PM
mbates50's Avatar
Old Apr 30, 2016 | 05:24 PM
mbates50's Avatar
BUT
Nothing about this POS has been normal
Old Apr 30, 2016 | 08:01 PM
Bhpbug's Avatar
Default Oil pan gasket...
I own an '03 XK8 w a 4.2L and I too see oil that appears to be coming from the oil pan gasket. I have looked for oil coming from above but nothing. I just received the new gasket and will replace the old one soon so, you may not have the only one leaking. BTW, my wife's '07 hyundai elantra had a leak at the oil pan gasket as well... it was just silicone seal but it had to be replaced.
Old May 1, 2016 | 12:09 PM
mbates50's Avatar
Yep. It was the oil pan gasket. A little over $300 parts and labor.
al_roethlisberger
Jul 16, 2024 04:19 PM
Ismael S
May 8, 2016 12:57 AM
Terry007
Apr 17, 2016 09:51 AM
jetjack
Apr 11, 2016 02:46 AM
gthawk1
Apr 6, 2016 01:25 AM
