Oil Pan gasket replace
Old Jan 25, 2011 | 03:44 PM
megatrack's Avatar
Default Oil Pan gasket replace
Hi,
After trying without success to find the answer in the Sticky FAQ I would like to know if there is anything special that I need to know before replacing my sump pan gasket(like torq) etc. in a matter of fact I have 3 leaks.... 1- leak oil pan, 2- leak power steering oil, 3- coolant leak. taking it apart on thursday... wish me luck
Thanks for helping
AJ
Old Jan 25, 2011 | 07:23 PM
H20boy's Avatar
torque specifications are listed in the Vehicle Specification pdf file in the FAQ section. Numbers 2 and 3 leaks sound like me just a few months ago. I counted them up recently, I've had 4 coolant, 2 power steering, and 1 oil (it was a line leak, not the pan).
Old Jan 25, 2011 | 09:37 PM
Reverend Sam's Avatar
Matt, that's weird that you have so many leaks and I have had none. Our cars are nearly identical. How many miles are on yours now?
Old Jan 26, 2011 | 10:35 AM
H20boy's Avatar
I'm in the 123k area now. Many came in the last 30-40k.
Old Jan 29, 2011 | 10:58 PM
megatrack's Avatar
The spec says 12NM which is 106 inch pound??? something's wrong here!!!
Can someone verify this for me please?
Old Jan 30, 2011 | 12:01 AM
Dan R's Avatar
[quote=megatrack;299170]The spec says 12NM which is 106 inch pound??? something's wrong here!!!
Thanks[/quo
Old Jan 30, 2011 | 06:59 AM
Glenn Barickman's Avatar
106 inch pounds = about 9 foot pounds. does that help. If your are like me and grew up working on US cars, the toque settings for these cars are hard to get used to. most of the bolts are just above finger tight, but they will work
Old Jan 30, 2011 | 10:56 AM
Dan R's Avatar
[quote=Dan R;299185]
Thanks[/quo
12Nm = 106in lb. I checked it using the software tool Torque Converter available for free at www.boltscience.com
Old Jan 31, 2011 | 09:10 PM
H20boy's Avatar
when we are normally used to 'ft-lbs', the in-lbs number (conversion) seems fairly large. Torque wrenches may or may not show 'in-lbs.
Old Feb 2, 2011 | 10:19 AM
oldmots's Avatar
For accuracy, please give the year and model of the car. I'm not sure if the pan gasket for the 4.0 is the same as the 4.2. I know the 4.2 gasket is a small silicone one set in a groove in the pan adapter on the engine. The bolts are torqued to about 9 ft lbs. The groove and the pan should be cleaned with lacquer thinner ( degreased) prior to installation.
JarodL
Mar 7, 2024 01:39 AM
kelliott
May 31, 2022 05:26 PM
Sprayall
Sep 3, 2015 07:49 PM
laserguy
Sep 3, 2015 02:02 PM
pnwrs2000
Sep 3, 2015 11:55 AM
