Overhead console / dome light keeps falling down – how to fix?
Old Mar 28, 2026 | 12:34 PM
Franca83's Avatar
Default Overhead console / dome light keeps falling down – how to fix?
Hi everyone,
I have a 2003 Jaguar XK8 and the overhead console (the dome light/sensor unit above the rearview mirror) has come loose.
It basically dropped down like in the picture, and when I try to push it back into place it will hold for a short time, but then falls again.
It doesn’t seem to “click” or lock properly anymore, so I’m guessing either the clips are broken or something inside isn’t holding it.
Has anyone dealt with this before?
  • Is this usually broken clips or missing fasteners?
  • Is there a proper way to secure it back (without damaging the headliner)?
  • Do I need to replace the whole unit or is there a simple fix?
Appreciate any advice — don’t want to make it worse.
Old Mar 29, 2026 | 02:39 PM
jhuertas's Avatar
I adjusted it, but I don't remember everything. There are some clips. Some of the plastic might have broken (in which case it needs to be rebuilt). Look at the whole assembly carefully; you'll see the solution. Check if there are any metal clips on the floor. Don't force the metal mesh (it deforms easily).
Old Mar 29, 2026 | 02:46 PM
if you look at the center of the picture, you can see the black spring clip on the white plastic assembly. That clip fits into a plastic bracket which has most likely fell apart. If you see the pieces inside the dome assembly, the can try and super glue it back together or you can try and find/purchase a replacement
Old Mar 29, 2026 | 03:42 PM
motorcarman's Avatar
Seek and ye shall find!!!!!!!!!!!
Topic beaten to death every once-in-a-while.
https://www.jaguarforums.com/forum/x...r-tips-292886/
Old Mar 29, 2026 | 07:51 PM
2500DollarXKR's Avatar
There are a few sellers on eBay that sell aluminum brackets that replace the likely broken plastic one. That solved my problem in about 5 minutes.
Edit: This is the one I got. ten bux: https://www.ebay.com/itm/405545425068
Old Mar 30, 2026 | 06:24 AM
jhuertas's Avatar
I remember now, I reinforced it by layering paper over the two-part epoxy adhesive I used to glue the plastic pieces. The paper (as long as it's not glossy) absorbs it and becomes rigid. However, the aluminum option seems better to me. I might buy it as a spare.
Old Mar 30, 2026 | 06:34 AM
jhuertas's Avatar
I went to buy it, but I saw that the aluminum one is for the XK8 convertible; mine is the coupe. But like I said, the paper and epoxy trick worked.
Old Apr 3, 2026 | 11:07 PM
Franca83's Avatar
thanks for the message, but with mine the problem seems to be with the black plastic clip, not the plastic bracket. You can see from the photo that one side of the clip is missing. Any ideas?
Old Apr 3, 2026 | 11:08 PM
Franca83's Avatar
Old Apr 4, 2026 | 01:32 AM
jhuertas's Avatar
Although it's unrelated to your problem, this video might be helpful for seeing how to completely disassemble it (
). I can't quite see in the photo which piece is broken, but if it's one of the tabs that hold the plastic clips, the solution is difficult. You can try using a piece of plastic (ABS) and appropriate adhesive (preferably two-part). First, treat the surfaces by sanding and applying an activator. Use the largest surface area possible (using the thinnest piece of plastic and applying the adhesive to the base and sides in successive layers).
olivermarks
Feb 7, 2026 09:26 PM
skubeedoo
May 8, 2020 07:28 PM
srpope80
Jun 16, 2017 02:15 PM
joe01952
Oct 16, 2013 05:24 AM
rivs
Nov 7, 2007 12:08 PM
