Part number
Old Jun 28, 2020 | 12:46 PM
alanroberts50's Avatar
Default Part number
Hi the large plastic cover that covers the whole top of the engine looks like it should be joined together at the rear by the firewall with some kind of clip. Anyone have a part number an does it just slide in or would there be screws too?
many thanks
Alan
Old Jun 28, 2020 | 01:45 PM
avern1's Avatar
For what it is worth here is the part number NJA1819AC. It is a rubber sleeve that joins the ends. The unit is no longer made and only available from a parts car that might still have one. Maybe I should try to figure out a rubber sleeve that would work. I wonder how many like me needs one.
Old Jun 28, 2020 | 01:59 PM
Known as an Engine Cover Spacer. There's a used one listed on ebay in Fort Wayne, IN if you're quick:
https://www.ebay.com/itm/Used-Jaguar...-/133412441264
Old Jun 28, 2020 | 05:00 PM
avern1's Avatar
Good catch Graham, I snagged one. Thanks,
Vern
Old Jun 28, 2020 | 05:10 PM
michaelh's Avatar
Most of us, I suspect. I've only ever seen one picture of a motor with that in place. Looks like a piece of bicycle inner tube might work.
$10 + $25 postage to Europe? Er - I'm good, thanks.
Old Jun 28, 2020 | 07:15 PM
avern1's Avatar
michaelh, when i get it i will do some measuring and let you know if a bicycle tube will work.
Old Jun 29, 2020 | 03:29 AM
Originally Posted by michaelh
Most of us, I suspect. I've only ever seen one picture of a motor with that in place. ......
If the pictures are that rare, here's another example on my 2001 XK8:
I suspect that, because they are awkward to refit, many don't bother.
Old Jun 29, 2020 | 04:25 AM
bladerunner919's Avatar
I still have mine - I didn't realise how charmed I am! Maybe I'll glue it to one side of the covers so that I don't lose it.
Old Jun 29, 2020 | 06:35 AM
michaelh's Avatar
Thanks, Vern,
It looks like it's a moulded piece, but even a strip of inner tube will be less offensive to my OCD than the loose ends (sad, I know).
Old Jun 29, 2020 | 09:50 AM
Originally Posted by GGG
+1
Thank you!
i have a more serious issue brewing surrounding coil packs and may repost for more help. You guys are amazing!!!
hhv00586
Sep 19, 2021 03:32 AM
thebiglad
Jun 25, 2013 03:25 PM
Humy
Mar 29, 2012 09:22 AM
