Quick Question 1998 XK8 Cruise cntrl button does it light up?
Old Jun 24, 2014 | 02:32 PM
Johnken's Avatar
Default Quick Question 1998 XK8 Cruise cntrl button does it light up?
I just realized that the cruise control button does not light up like the Sport mode does in my car. I have no recollection as to whether it ever did. Would you mind telling me, are they supposed to?
thanks,
John
1998 XK8
Old Jun 24, 2014 | 02:54 PM
RJ237's Avatar
Yes it does light up. Does your cruise control work?
Old Jun 25, 2014 | 09:09 AM
Johnken's Avatar
Default Thanks
Thanks a bunch. Cruise control itself is fine, looks like I now have my first interior bulb to replace. I appreciate your help. John
Old Jun 25, 2014 | 05:42 PM
reb1999's Avatar
Yes, does light up. You may need to replace the switch if tell tale is your need.
Old Jun 25, 2014 | 06:00 PM
Davebc's Avatar
Do you mean the switch on the steering wheel illuminates when lights are on? Does this also mean the radio controls on steering wheel light up too?
Is something supposed to come on the dash to indicate cruise is engaged?
Old Jun 25, 2014 | 07:24 PM
Jandreu's Avatar
Davebc, the OP is talking about a 98, they have a seperate switch beside the sport button that turns the CC on and off. Our 03's do not have that, just the steering wheel controls that do not light up like the instrument lights. The CC in our cars is always on, you just engage or disengage it.
Old Jun 26, 2014 | 06:47 AM
jamdmyers's Avatar
I recently have replace my Mode switch on a 02, I had the old one saved and popped it open, there is a led if you are handy that could be replaced if it's just the light, mine would not stay engaged, I suspect the light is similar on the cruise. That switch base has 4 snap slots, you can easily pry the top off.
Attached Thumbnails Quick Question 1998 XK8 Cruise cntrl button does it light up?-modeswitch.jpg
Old Jun 26, 2014 | 11:46 AM
Johnken's Avatar
Default I should have realized LED vs incandesent
Jam, Thank you for the offer. As I was driving home from work last night I realized that the way I phrased the question would probably be taken as "does the red LED light?" I appologize, my LED is fine. I should have asked about the lighting that goes on with the headlights / Dimmer. The S on the sport button is lit at night, I was wondering if the icon on the Cruise control has white backlighting too.
Thank you for the offer though.
John
Jaguila
Sep 5, 2015 06:16 PM
tony bosco
Sep 1, 2015 02:06 PM
aquifer
Aug 29, 2015 04:54 PM
Stuart S
Aug 29, 2015 11:37 AM
Robgodius
Aug 25, 2015 09:34 PM
