Radiator filler point
Old Mar 20, 2010 | 01:31 PM
hafferf's Avatar
Cool Radiator filler point
Hello Folks!!..
I smelled some antifreeze the other day, and I traced it to that little tank where you put in the fluid. It seems to be weeping out the bottom. Would that be around the sensor?. Should I just replace the sensor, or do I need to do something else??...
Thanks for the info..
Fast Freddie
98 XK8
Old Mar 20, 2010 | 02:44 PM
Gus's Avatar
Gus
The opening for the sensor allows the sensor to fit into the tank but does not make contact with the coolant. It is isolated. Your tank has sprung a leak and is either a clamp or a crack. I have a little information on the tank http://www.gusglikas.com/AutoRepairCoolantTank.htm
Old Mar 21, 2010 | 02:58 AM
H20boy's Avatar
I found it easier to simply replace the tank. Mine was cracked on the bottom. A new tank comes with a sensor, and brand spankin new cap as well.
That is, of course, after you confirm, its not just a split hose or bad connection to your tank.
Old Mar 23, 2010 | 01:23 PM
hafferf's Avatar
Thumbs up
OK!!... Thank you fellas for the info. And Gus, thanks for the additional.... does anyone have the part number for the tank??
Thanks Folks
Fred
Old Mar 23, 2010 | 06:08 PM
hlgeorge's Avatar
Reservoir:
MJD4400AB OEM $203.00
Old Mar 23, 2010 | 06:21 PM
test point's Avatar
Available at some of the on-line sources in the $120 range. Bought mine at a wreaking yard for $50.
Tight Wad Tom
Old Mar 23, 2010 | 07:02 PM
Gus's Avatar
Gus
Thanks Folks
Fred
Fred,
It sounds like you need a tank. Go to http://www.motorcarsltd.com/ They may have a used one if that is what you are looking for.
Old Mar 23, 2010 | 07:08 PM
Gus's Avatar
Gus
Tight Wad Tom
Tom,
Reloaded 500 45’s today and plan to spend Wednesday shooting them up. I will try not to think about the cars!
Old Mar 23, 2010 | 07:37 PM
test point's Avatar
I know!
Weather is great . . . for a big change.
No time to unload brass . . .
Parts in and rebuilding suspension of my old Volvo. All the old bad out today, all the good new in tomorrow. Think I just bent the ball joint 'C' clamp I 'rented' through a local AP store. Twenty-eight year old wishbone bushings do not want to give up easy. Four foot pipe on a breaker bar is hard to resist.
Note on Volvo suspension . . . after 28 years, two of the wishbone bushings had failed, two were still serviceable.
Old Mar 23, 2010 | 08:24 PM
Gus's Avatar
Gus
I know!
Well you have your fun and I will have mine. I thought you would have finished the Volvo. Do you have a thing for cars owned or influenced by FORD???
1100me
Jul 24, 2023 06:10 PM
kelliott
May 31, 2022 05:26 PM
Blaine Trarop
Sep 23, 2015 03:08 PM
Jefro
Sep 15, 2015 01:44 PM
1100me
Sep 7, 2015 06:26 AM
