Rear lamp warning, but all are working
Old Oct 19, 2015 | 12:24 AM
mhminnich's Avatar
Default Rear lamp warning, but all are working
I'm getting a rear lamp warning but all lights are working. Anybody experience this? Thanks
Old Oct 19, 2015 | 02:18 AM
Johnken's Avatar
yes check for corroded connections (bulb to socket). I have seen that do this.
Old Oct 19, 2015 | 02:28 AM
JonWat's Avatar
There are many threads, including this one:
https://www.jaguarforums.com/forum/x...d-35083/page2/
Old Oct 19, 2015 | 07:21 AM
test point's Avatar
There have also been issues with the brake light switch causing this error.
https://www.jaguarforums.com/forum/x...esolved-36309/
Old Oct 21, 2015 | 07:11 AM
Stamford's Avatar
+1 on the brake light switch. Mine failed this year, but for a while I had rear lights even though I was getting the check rear lights message. Eventually they stopped working.
Old Oct 21, 2015 | 10:53 AM
Chuck Schexnayder's Avatar
As others have stated above on Brake Light Switch.
Have the switch replaced or, do it your self. Problem will be solved.
Old Oct 21, 2015 | 11:13 AM
brgjag's Avatar
ahh, this feeds into that thread here about modern cars or what ever. Over cooked system to tell you a light it out that you have to chase down multi possibilities to wehat the cause it. NOT NEEDED. Bulb goes out, you see so evenutally and you place it, not all this computer boards and the like. ha ha ha
Old Oct 28, 2015 | 04:33 PM
theweeb's Avatar
This just started happening to mine, confirming what I suspected, the brake switch. Will replace it and see if it clears up the warning as well as letting me use the cruise again. My commute is typically 45 minutes in moderate traffic, and the adaptive cruise is a godsend (along with the killer stereo system). Thanks for posting this and links to the other threads!
Old Oct 28, 2015 | 04:45 PM
theweeb's Avatar
Wait a minute, $173.95 for a freaking little switch? Does anyone else have a better source? Is it the adaptive cruise that makes this so expensive?
http://www.autopartswarehouse.com/sk...3-1656598.html
Old Oct 28, 2015 | 05:49 PM
Paul Pavlik's Avatar
$104.79 at Rockauto.com:
More Information for STANDARD MOTOR PRODUCTS SLS503
Old Oct 28, 2015 | 06:25 PM
michaelh's Avatar
Sad but increasingly true. The lunatics have taken over the asylum. Perhaps we need a sensor to alert of a faulty sensing circuit - not.
theweeb, if you can wield a soldering iron (or know someone who can) , the microswitches are standard and available separately for around $3 each. Someone posted a part # on the forum. The bracket can be a bear to R & R, but there are some useful tips on here.
Unfortunately the price of many spares reflects what the market will bear rather than true worth. That's business..
Mike
Old Oct 29, 2015 | 10:43 AM
fmertz's Avatar
Check Advance Auto, under cruise control switch.
Also, there was a member of this forum that fixed them for a while. You could order a repaired switch under the promise of sending your old one back to him, so there was no down time for you.
Old Oct 31, 2015 | 05:53 PM
MikeAlford's Avatar
Fix brake switch using magnetic actuation
Donzi
Sep 5, 2017 03:53 PM
tassiejag
Jan 16, 2016 01:55 AM
Bcrary3
Oct 27, 2015 09:04 PM
garyp
Oct 23, 2015 06:13 AM
Dylj
Oct 18, 2015 09:03 AM
