Rear panhard frame
Old Nov 11, 2013 | 10:01 AM
dpm's Avatar
dpm
Default Rear panhard frame
Can anyone tell me how to remove this, all bolts removed but am unable to get the frame out.
Old Nov 11, 2013 | 10:22 AM
Is it the Subframe ('A' Frame - item 11) you're trying to remove?
Old Nov 11, 2013 | 11:30 AM
dpm's Avatar
dpm
Hi Graham, no it's the tubular frame with the 4 bushes, I am assuming it's called the rear panhard.
Old Nov 11, 2013 | 02:12 PM
The Stabiliser Bar Mounting Frame at the back ........
Items 8, 11 and 13.
Is there even sufficient room to manoeuvre that without disconnecting and lowering the suspension sub frame?
Old Nov 11, 2013 | 04:50 PM
dpm's Avatar
dpm
Thats it number 13, I have some powerflex bushes for the panhard, is that what the panhard is or am I trying to remove the wrong thing?
Old Nov 11, 2013 | 05:39 PM
There's a bush either side (at 'position 13') on the Monostrut and two more on the bottom of the Stabiliser Bar (item 11).
The 'position 13' bolts are obvious but have you disconnected the right ones at the bottom?
The bottom pair are arrowed in the upper diagram which is looking forward from the rear of the car.
The 'position 13' ones are arrowed in the lower diagram as seen looking up from beneath the car.
Old Nov 11, 2013 | 08:26 PM
dpm's Avatar
dpm
Thanks Graham, All bolts removed, just cant see how the frame is removed to fit the new bushes. Can anyone confirm that this is known as the panhard.
Old Nov 12, 2013 | 04:08 AM
Jaguar call it a Bushed Differential Strut!
(click on image to enlarge it)
A Panhard Rod provides lateral location for a 'live' axle. A Watt's Linkage is a further advance which also provides vertical control.
The Jaguar Strut is a progression on these principles but I suppose you could call it a Panhard Rod as that is effectively the function it is perfoming.
Old Nov 12, 2013 | 05:50 AM
dpm's Avatar
dpm
Thanks Graham, as there are 4 bushes in the powerflex kit described as XK8 rear panhard bushes I guess this is the item they fit. Still trying to see how to remove it from the car though, all 4 bolts are out but there doesn't seem to be enough clearance to get the frame out. If anyone has done this job themselves I could do with a bit of advice as to how they got this panhard out. Thanks.
Old Nov 12, 2013 | 06:24 AM
dpm's Avatar
dpm
O.K. the package that the bushes are in describe them as rear axle brace bushes so I guess this is the correct part I am trying to remove,
Old Nov 12, 2013 | 08:23 AM
JTIS procedure is to release the front 'A' Frame brackets and lower the diff approximately 25 mm to give sufficient clearance to allow removal of the Strut.
Old Nov 12, 2013 | 09:58 AM
dpm's Avatar
dpm
Many thanks Graham, are they the brackets that hold the big bush? and do I unbolt the bolts on the front of the bracket the ones that attach the bracket to the floor of the car?
Old Nov 12, 2013 | 10:59 AM
Here's the relevant section from JTIS:
JTIS - XK8 Differential Strut.pdf
Even with the two brackets at the front of the 'A' Frame released, the bushes are often seized on.
Old Nov 15, 2013 | 09:32 AM
dpm's Avatar
dpm
Spot on with the advice Graham, couple of the bolts, one of the long ones and a bracket bolt difficult to get out nearly rounded the heads, managed to hammer on a 18mm socket to get bolts out O.K. The bushes on the panhard/brace easy to remove they have a plastic sleeve. just got to put it all back together now, when I can find a couple of bolts. Thanks.
Old Nov 15, 2013 | 09:53 AM
An easy job with the suspension out but not a lot of room with it on the car.
Good to hear it definitely is essential to drop the suspension for clearance. There's often shortcuts can be made on recommended JTIS procedures but I didn't think it would be possible in this instance.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
sadepol01
Sep 11, 2015 05:26 AM
1964Daimler
Sep 9, 2015 11:28 AM
EZDriver
Sep 8, 2015 09:25 AM
