Rear Shock replace question
Old Nov 1, 2014 | 02:56 PM
Borg524's Avatar
Default Rear Shock replace question
Ran into a little problem today while trying to replace the rear shocks and I have a question for anyone who has done this job before. I have the spring compressors in place and I went to remove the bolt connecting the shock to the wishbone. I got the nut off fine, but I can't seem to get the bolt out. The bolt will not turn at all, even with a breaker bar or impact wrench. Is the bolt threaded into the wishbone itself in which case I should continue trying to thread it out, or is it just pushed through and I should try hammering/prying it out? Any help would be greatly appreciated. Thanks.
Old Nov 1, 2014 | 03:06 PM
RaceDiagnostics's Avatar
It should just pull out, try tapping it out with a hammer. I'll have a look for a picture.
Old Nov 1, 2014 | 03:39 PM
I did this a few years ago, the bolt tapped out with a drift.
Old Nov 1, 2014 | 04:08 PM
cjd777's Avatar
Use a jack and a large socket and take some of the pressure off, just jack the bottom of the shock up a bit. A bottle jack will do. Don/t forget to mark with a good marker the pin going through the rear hub.
Wayne
Old Nov 2, 2014 | 11:55 AM
Borg524's Avatar
So I finally got the bolt out. Turned out that the lower bushing on the shock was the problem. I tried hitting it with a torch but it still didn't budge. I ended up cutting through the bottom of the shock and through the bushing, then the damper bolt just tapped right out. Thank you all for your help.
Old Nov 2, 2014 | 12:55 PM
cjd777's Avatar
Good for you and glad to see it is progressing.
Wayne
BrentGardner
29
Dec 16, 2024 12:13 AM
rsmartin
39
Nov 12, 2021 01:09 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
aquifer
Aug 29, 2015 04:54 PM
dpappyp
Aug 27, 2015 06:31 AM
