Rear shocks, done!
Had the new rear shocks sitting in the basement for over 6 months, just lying there and intimidating me. This morning, I brewed the courage to tackle the job and with the help from my son and the info on this forum my rear end no longer sounds like a coffee can with a few bolts rolling around. It's a whole new car!
How anyone was able to use spring compressors for this job, my hats off to you, there is no way mine were even close to fitting. I used a tip found on this forum, removing the back plate bolts and bending down.
I was able to do the passenger side without removing any brake components, the drivers side I did need to remove the caliper. I did the passenger side first and that took a while, but, once one side was done the second side was much easier, just due to the experience from the first side.
Overall, I wouldn't call it a very hard job, but not easy either. Especially, when having a limited set of tools and performing the job in the driveway.
Glad it's done!
Glad it's done!
That is why we always bent the plate DOWN and replaced the springs/dampers the safe way for X300/X308/X100.
bob
The 'trapezoidal' shaped plate in the bottom of the suspension cage prevents the lower control arms from falling low enough to remove the damper/spring.
The lower arm hits the plate!!!!!!
Bend the plate DOWN and the lower arm falls farther!!!!
bob
bob
I literally stared at it for over 15 mins thinking the same thing, honestly still don't get it, but, it worked.
