rear universal joints
Old Mar 11, 2026 | 01:02 PM
66RBS's Avatar
Default rear universal joints
my 2003 xk8 has to have rear cv joints replaced. local shop says not available
anyone know of a source
Old Mar 11, 2026 | 01:57 PM
Hell-Cat's Avatar
No if you are referring to the driveshaft then I think that UJ will be a little challenging. If you are refering to the axle shafts then those UJs are readily available.
The Jaguar driveshaft diagram shows the shaft to be a one piece unit, the UJ is not shown seperately. But....
Looking at the images of the driveshaft, that UJ is serviceable and is clipped not staked. A call to a driveshaft specialist might yield the correct UJ which is probably a Ford part anyway. Alternatively thay might be able to rebuild and balance your existing unit which would be beneficial beyond just the UJ installation.
You will be able to get that UJ somewhere, Jaguar don't make UJs so they picked it up somewhere.
Old Mar 11, 2026 | 02:00 PM
Rex's Avatar
Rex
Rock Auto
Old Mar 11, 2026 | 02:01 PM
Hell-Cat's Avatar
Originally Posted by Rex
Rock Auto
Yup, but not the driveshaft UJ.
Old Mar 11, 2026 | 02:09 PM
Rex's Avatar
Rex
Says rear half shaft?
Old Mar 11, 2026 | 02:16 PM
Hell-Cat's Avatar
Yes, that's the axle shaft from the diff to the road wheel. They don't have the actual drivehshaft (gearbox to diff) UJ listed unfortunately. Jaguar shows the driveshaft as a none serviceable single assembly, even though the UJs are clipped and will be replaceable - once you can find the correct UJ.
Old Mar 11, 2026 | 03:45 PM
66RBS's Avatar
Default ujoint
Jagbits is showing universal joints new for $43
i get those if mechanic says he can’t find
Old Mar 11, 2026 | 03:51 PM
Rex's Avatar
Rex
Is it not the axles we are talking about? If so, Rock Auto much cheaper.
Old Mar 11, 2026 | 04:28 PM
Hell-Cat's Avatar
No idea, the OP just says rear ubiversal joints but doesn't qualify which UJs.
Old Mar 11, 2026 | 04:29 PM
Chirpy's Avatar
If half shafts (from differential to rear hub), then JLM1388 (SNG Barrett, etc.). Agree Rockauto should be fine - same as used on XJ6, etc. On a quick measurement of a spare one, it looks likely to be a greaseable 1350 series UJ (1 3/16 diameter by 3 5/8 length), but without digging out the vernier caliper I can't confirm. Also probably listed as GKN U220.
If driveshaft, then the 2 piece XKR one uses 1300 series UJs, non greasable, on the rear driveshaft (1 1/16 dia by 2 15/16 length). Note 1300 series, definitely not 1310 series.
So I would expect, but can't confirm that for driveshafts you would need 1300 series.
Old Mar 11, 2026 | 05:36 PM
66RBS's Avatar
Default cv joints
could not find axle or cv joints on Rock auto
Old Mar 11, 2026 | 05:52 PM
Rex's Avatar
Rex
The term “CV” joint may be a problem. My understanding of that term is always in reference to front wheel drive axles. You have a simple rear wheel drive with independent rear axles and U joints. Simple tech.
michaelh's Avatar
Oddly, Rockauto doesn't show the diff/hub axle UJs for MY2003, but does for the earlier cars. The JEPC shows the same part # (as noted by chirpy) for all cars.
Old Mar 11, 2026 | 06:17 PM
Chirpy's Avatar
So assuming you want the universal joint(s) for the half shaft, i.e. part 2 below:
Using Jaguar part number JLM1388, which is the OEM part number, supplier choices include SNG Barratt, Moss Motors, Jagbits, etc.
for Rockauto you have (use the search function, or look up any XJ6, e.g. 1996 XJ6 Vanden Plas):
GMB 2150178, FVP 2100178, FVP 2150178
Noting that the listed dimensions in the ‘info’ details match 1350 series universal joint
(in which case I would probably go for Spicer 5-178X, since I find Spicer parts to be good quality)
Please double check using your own research before ordering, in case I fat fingered something.....
Old Mar 11, 2026 | 07:16 PM
66RBS's Avatar
Default cv or univ joint
yrs i want part 2 in the diagram below.the shop is calling them cv but i call them universal joint
Old Mar 11, 2026 | 07:47 PM
Hell-Cat's Avatar
Cool
Find a different shop
Ray Ray
May 23, 2023 09:04 AM
Norcat
Aug 1, 2022 12:13 PM
pezzonovante88
Sep 2, 2011 07:31 AM
Bodyman
Aug 19, 2011 08:10 AM
Humy
Jun 16, 2008 06:19 PM
