Rear wheel bearing replacement.
Old Jun 13, 2023 | 12:59 PM
Ant Buck's Avatar
Default Rear wheel bearing replacement.
Is there a walk thru on replacing the rear wheel bearings?. I have some play that was noted when it had it's mot. Are they plain bearings that are tightened as tight as possible, or taper fit. Many thanks . Anthony.
Old Jun 13, 2023 | 01:24 PM
michaelh's Avatar
Be aware that some play 6-12 o' clock is normal, or could be other than the wheel bearings - take a look at this thread:
https://www.jaguarforums.com/forum/x...4/#post2552458
Old Jun 13, 2023 | 01:36 PM
Ant Buck's Avatar
Thanks for the reply, i will get the car off the ground and check it. I noticed looking back through previous mot's it was mentioned as having slight play in osr bearing. There is no noise from it, so will probably leave it alone.
Old Jun 13, 2023 | 06:40 PM
xalty's Avatar
side to side is 99% of the time dried up knuckle bearings up and down is usually the output.
find a tester than understands how old cars should be
Old Jun 13, 2023 | 07:41 PM
Johnken's Avatar
Ant, fyi, yes there are several write ups. I'm sure I was involved in a few :-).
One nice surprise, the last time I did this, I just ordered rear wheel bearing kit from jaguar. Price was on the reasonable side, but the big surprise (?) - they ship Timken bearings, a brand my mechanic friends always put at the top of their list.
Heads up: if you do the job or start messing around with tightening the axle nut - buy a new nut. Trust me they aren't kidding that it IS NOT reusable.
J
Old Jun 14, 2023 | 01:15 PM
Ant Buck's Avatar
J
Thank you for you reply, Timken are supposed to be the best quality, thanks for your help. Anthony.
mcphill
Apr 13, 2023 11:37 AM
Dmcr
Dec 15, 2021 03:29 AM
Freebird
May 9, 2021 11:43 PM
TN8Shooter
Jun 5, 2012 12:18 PM
walkman1
Nov 16, 2010 11:47 AM
