Rear wing repair
Old Jul 17, 2014 | 04:28 PM
  #41
RaceDiagnostics's Avatar
Originally Posted by steeevo
would you not recommend a product called kurust from hammerite we stock it at work and I'm thinking of giving it ago on my wheel arches before it gets to far. but realistically i need new donor wings but thats some serious work.
Look at the pics in the post from the start of this thread, yoiu will se it was a waste of time.
Old Jul 19, 2014 | 04:32 PM
  #42
Here is what I plan as an alternative air vent. I plan to put in three of these so there is not too much of a restriction. They should tuck away behind the carpet.
I will probably also use the two access holes for the wires used for the US bumper lights as they are redundant on my car.
Old Jul 20, 2014 | 07:02 AM
  #43
DevonDavid's Avatar
Had a look at the easy side (LH) of mine yesterday, and although there was a fair bit of dry dust and dirt, there doesn't appear to be any rust. Was tempted to scrape it back to bare metal but decided it was probably better to leave things pretty much as they are. Gave it a fairly gentle clean up, a liberal spray with waxoyl, and put it all back together again. I'm now undecided as to whether it's worth the considerable additional work to have a look at the other side with the complications of CD changer, amplifier, hydraulics etc.
Mine is a '97 car, with four previous owners and 120k miles, but I think I'm lucky in as much as it can't have been used much in winter, when the roads are salted and rust can really get a hold in these hidden places.
Old Jul 20, 2014 | 05:08 PM
  #44
Make sure the drain hole is clear and you mag get lucky.
Old Jul 20, 2014 | 05:33 PM
  #45
DevonDavid's Avatar
RD. I don't think I have a drain hole. There's obviously the big aperture for the flappy venty thing, but other than that and the grommet-covered holes at a higher level, nothing else !
Old Jul 21, 2014 | 04:09 PM
  #46
There is a tiny hole about 3mm across in the very lowest area where the outer and inner walls meet with the bottom of the wheel arch, yours is filled with dirt. If you clean it out you will find the hole.
Old Sep 20, 2014 | 11:39 AM
  #47
Default I hope this is the end of the story.
I picked up the car from the painter this morning. They had rebondo'ed my filler attempts, blended base coat over the repairs, round the wheel arches and along the sills then clear-coated the entire rear wings, sills and right rounds the back of the car. They have done quite a good job, I can see it because I know it is there but it is good enough. Just hope it last for at least 10 years. I should have cleaned the wings before taking the pics as they are a bit dirty after driving the car in rain today.
Old Sep 20, 2014 | 12:54 PM
  #48
You've put in a lot of hard work.
It's come on a long way since we went round it in Glasgow. I hope this is the end of the battle against rust and it lasts for many years now.
Old Sep 20, 2014 | 02:57 PM
  #49
nicely done!!!
Old Sep 21, 2014 | 07:36 PM
  #50
RCSign's Avatar
Race
Nice work, Looks nice Good Luck
FrickenJag
Jun 16, 2025 02:15 PM
trosty
Dec 17, 2021 07:41 AM
KarimPA
Sep 12, 2015 08:15 AM
edtexas
Sep 4, 2015 08:20 PM
brgjag
US Midwest
Sep 4, 2015 11:24 AM
