Repair or replace? Advice sought.
Old Oct 16, 2014 | 04:59 PM
frankc's Avatar
Default Repair or replace? Advice sought.
Easier to show you than explain
and
I have a guy who is going to respray other bits of the car for me but says this is too minor for him. I would not mind having a go myself but need advice. Anyone repaired , resprayed or replaced these?
Old Oct 16, 2014 | 05:07 PM
RaceDiagnostics's Avatar
Repair for now and watch out for good second hand replacements on ebay here or the US.
Old Oct 16, 2014 | 06:28 PM
cjd777's Avatar
Frank, are you going to take it off or in place. Off would be better as I bet it's even more rusty on the inside.
Sand, primer, sand, primer until smooth, then the final coat.
Wayne
Old Oct 17, 2014 | 10:21 AM
frankc's Avatar
Wayne
I am going to try and take it off to do it. I think I have found the paint for it on ebay complete with can of lacquer coat for around £17. Expensive for a tin of paint but hopefully worth it.
Would prefer to take it off as you can get a better finish on it, and not the car, also it may well be rusting underneath. I will not know until I actually get it off. One or two other jobs to do before hand. Taking it for a Hunters alignment next week. Should be interesting as its never been aligned since new as far as I can tell.
Old Oct 17, 2014 | 10:24 AM
K.Westra's Avatar
Granted quite a few of my pictures have dissapeared, but check out this:
https://www.jaguarforums.com/forum/x...rim-faq-55561/
Old Oct 17, 2014 | 11:14 AM
frankc's Avatar
Good link and info thank you. However the later messages confused me slightly referring to lifting up the trim in the middle, I assume they were talking about the boot/trunk of the car?
Just been out and tried to lift mine off. It wont budge. I do have a trim removal tool, the flat bit of strong plastic, but I am worried about damaging the paintwork of the door.
Old Oct 17, 2014 | 06:19 PM
If it's on really tight, removing the door card will allow you to get a better grip and pull it upwards.
It shouldn't need any tools.
Attached Thumbnails Repair or replace? Advice sought.-02-os-door-waist-seal-trim-removed.jpg
Old Oct 17, 2014 | 06:43 PM
K.Westra's Avatar
I'm wondering if some of the early cars had them glued on since I never was able to get mine to come off. I know JTIS says the mirrors need to be removed, but I didn't try it that way and just did it in place.
Old Oct 18, 2014 | 05:28 AM
It has to be lifted clear right up to the mirror and then slid rearwards to release. As can be seen form the photo in post #7, I didn't need to remove the mirrors on my 2005 XK8.
Old Oct 18, 2014 | 09:28 AM
frankc's Avatar
When I get brave I will give it a go. I think the secret of this is to find a bit that will lift and work the rest out. There is no rush. My car does not go in for its respray/touch ups until December. Still very busy with other bits and pieces.
Its going in next Thursday for a Hunters Alignment so will also get a good look underneath then too.
JarodL
Mar 7, 2024 01:39 AM
Sprayall
May 30, 2021 08:13 AM
jehart49
Sep 12, 2015 05:36 PM
MarathonJohn
Sep 3, 2015 07:59 PM
Sprayall
Sep 3, 2015 07:49 PM
