Replacement Seats 99 XK8
Old Nov 8, 2024 | 07:07 AM
AbnMike's Avatar
Default Replacement Seats 99 XK8
So my driver's seat is worn, and that fabric above the hinge area is in dire need of fixing.
I can order new leather and have a shop replace.
I can find new seats and just replace.
I found these on FB Marketplace. No real information other than "seats came out of a 4 door jaguar"
They're the same color (cashmere) as my car - and the price is silly cheap ($275, which is less than a quality leather cover). I obviously don't need the rear seats, etc.
Will these two front seats work in a 1999 xk8?
Thanks!
Old Nov 8, 2024 | 10:15 AM
Jon89's Avatar
My guess is that the bolt patterns holding the seats to the seat rails will not match up....
Old Nov 8, 2024 | 12:15 PM
Y2KJag's Avatar
Much depends on the year of the seats. The wiring harness connector may not be the same. These seats probably have the adjustable headrest, which may make a difference in the connector. I have no idea if Jag kept the seatbelt tensioner explosive thingy the same through the years, which may also make a difference.
Old Nov 8, 2024 | 01:06 PM
Don B's Avatar
Hi AbnMike,
I doubt those seats would fit your car without major modifications. The seat slides & mounting rails for the X100 are flat with both the front and rear screws threading into the floor pan vertically:
On the sedans, the mounting rails have a bracket welded to their front ends at 90 degrees, and the front screws thread in horizontally. See the bracket where screw #13 mounts:
Cheers,
Don
Old Nov 8, 2024 | 03:09 PM
AbnMike's Avatar
Thanks. I'll keep looking!
Blackbeard911
Dec 24, 2019 08:26 PM
new mexico
Oct 22, 2017 05:46 PM
Spikepaga
Dec 27, 2014 10:00 PM
Kevin Rambold
Jan 20, 2011 05:57 PM
