Replacing air filter
Can’t seem to get the cover off the air box for a filter replacement. Released the 3 spring clips outboard and 1 inboard, but cover does not move. What am I missing? Forum search feature gave me no joy…
There are three, IIRC, on the side nearest the fender. And one in the rear and another on the side nearest the engine. So, 5 total.
Hi,
since I changed the air filter last week: There are two or three visible clips near the fender. Then there's another clip towards the radiator and one on the left under the air intake hose. Just use a flashlight. I simply removed the entire mass airflow sensor hose all the way to the throttle body. There are only two screws at the throttle body to remove it. That makes everything very easy, including closing the air filter cover again.
Regards, Willi
Regards, Willi
Hi,
Regards, Willi
Regards, Willi
I use a long pick which has a right-angled hook on the end of it to hook around the clip and pull it down / flick it up.
Richard
removing the whole box also requires fiddling with the air intake snorkel.
don't know, but Malhe or Mann both make good quality ones, but not as cheap as others on Amazon. I’ve used them both.
https://a.co/d/02GKyWMn
https://a.co/d/0i8Cgq8j
Thanks for your helpful responses. I can confirm there are five spring clips that secure the top of the air box containing the air filter. Three are on the fender side, one on the front inside, and one on the rear inside. I was able to release all and check the filter which did not need replacement after all. I did keep the rear inside clip undone as it is difficult to reach.
take the extra minute and remove the intake tube and then have unfettered access to that pesky critter.
Z
Thanks for your helpful responses. I can confirm there are five spring clips that secure the top of the air box containing the air filter. Three are on the fender side, one on the front inside, and one on the rear inside. I was able to release all and check the filter whichb did not need replacement after all. I did keep the rear inside clip undone as it is difficult to reach.
I've worked on many cars which make air filter removal a much bigger hassle than on the XK8.
Richard
Considering the penny pinching ways of all car manufacturers, I don’t see Jaguar spending an extra penny to put in more latches than were necessary. The latch under the intake tube may be hard to reach, but that reason for leaving it unfastened seems thin to me.
Z
Z
chrislynn5
34
Aug 3, 2010 08:07 PM
