Retro fit Cruise control
Old Dec 10, 2012 | 02:35 PM
Wullie's Avatar
Default Retro fit Cruise control
Hi
My XK8 does't have cruise control fitted, I wondered if anyone has ever retro-fitted it with parts from damaged / scrap cars? is it possible?
Wullie
Old Dec 10, 2012 | 02:40 PM
dennisw's Avatar
Originally Posted by Wullie
Hi
Wullie
hello Wullie
what year is your xk?
Dennis
Old Dec 10, 2012 | 02:52 PM
Wullie's Avatar
Sorry should have said, it's a July 2000 4.0 ltr n/a engine
Wullie
Old Dec 11, 2012 | 09:04 AM
dennisw's Avatar
Wullie
ive never come across a xk with no cruise..is it a coupe or convert..if its a coupe you should have a button next to the sport botton.
come on graham..this is right up your street.
Old Dec 12, 2012 | 01:15 AM
XKRacer's Avatar
Yes it has been done..... You need to find member TonyS... He did a big write up on it on the XKEC forum..... You will have to join to view it unless you get hold of him through here
Old Dec 12, 2012 | 07:21 AM
Wullie's Avatar
dennisw
It only has a sport button no cruise button at the gear selector, it's a coupe. I would think all the wiring is there but requires that switch plus relays etc,
XKRacer, I will have a look for TonyS in the XKEC forum
cheers & thanx
Wullie
Old Dec 12, 2012 | 07:36 AM
XKRacer's Avatar
You will need a bit more than switches and relays I am afraid, you also need the vaccuum tank and solenoids.... Even though like you say, it is do-able
Old Dec 12, 2012 | 07:44 AM
XKRacer's Avatar
If you go into my profile Tony S is on my friends list
Old Dec 12, 2012 | 09:30 AM
Paul Pavlik's Avatar
Tony, If I'm not mistaken, the AJ27 Engine does not use any vacuum for the cruise, just ECM control of the Throttle Motor.
Old Dec 12, 2012 | 01:32 PM
XKRacer's Avatar
That is correct, the later engines it was all electronic...... XK8 on a 2000 would be an AJ27 if you had an XKR possibly still an AJ26..... Mine Is..... But that is besides the point as this is an XK8 which does pose the original question and one I must admit I am unsure of......
Maybe it could just be switches and a relay or two ?
aholbro1
Dec 29, 2024 06:46 PM
Skeeter
Sep 17, 2015 08:15 PM
texaspete
Sep 10, 2015 08:34 AM
edtexas
Sep 4, 2015 08:20 PM
XFR_Gold
Sep 2, 2015 12:24 PM
