serpentine belt.
Old Jul 29, 2023 | 03:56 PM
rumm5's Avatar
Default serpentine belt.
Hi all;
I can't get my belt back on. 98 conv. I had to replace alternator. I had trouble getting belt off. Then the tensioner pulley bolt broke. Had to pry pulley off to finish getting belt off. Couldn.t get bolt remnant out. Had to buy new assy. New assy on. I got the lever tool all the way over. not even close. I don't want to break this tensioner also. Belt correct length 91.5 inches. Compared a new one I have. Same.I know what the service info says, but is there something I don't know or some special trick to this? I thought I remember replacing a belt a while ago and didn't have near this trouble.
Don
Old Jul 29, 2023 | 04:11 PM
Jag#4's Avatar
I assume you have rechecked the belt location "map" as the installation can be confusing.
When I did this recently I also had difficulty in reinstalling. Checked new belt against the old, checked the belt map and applied creative cursing. After a few more minutes of frustration I realized my long ratchet used to release the pulley tension was hitting against a component in the engine bay. It was hard to see as I was pulling from the opposite side of the car to get leverage with one hand. Found a shallow socket for proper clearance and it went on first time with minimal effort.
It's worth checking to see if you really have hit the maximum release point as there is limited line of sight while doing this.
Old Jul 30, 2023 | 04:30 AM
RichardS's Avatar
Originally Posted by rumm5
Hi all;
Don
It should be a simple job on the X100. I've done it many times without a problem. You should also be able to move the tensioner pulley right over to the end of it's travel and the pulley bolt should definitely not snap. I wonder if you are moving the spanner/socket bar through its correct arc i.e. perpendicular to the arc travelled by the pulley.
Richard
Old Jul 30, 2023 | 06:24 AM
Jon89's Avatar
On my wife's 2006 XK8, replacing the serpentine belt is so much easier if I remove the radiator fan assembly first. The additional working room with that assembly out of the way makes all the difference....
Old Jul 30, 2023 | 08:35 AM
Timeisrelative's Avatar
Ill agree with double checking the belt routing. Also make sure the belt is actually in the pulleys. Also I think there is a bolt or something at the bottom of the engine that the belt can get caught on. Just something to check. Also make sure your new tensioner assembly is actually in the proper location
Old Jul 30, 2023 | 03:08 PM
rumm5's Avatar
Default alt pulley
Hi all;
I checked diameter of pulley ribs on orig alternator i have on other engine. Rebuilt unit pulley is more that 1/4 inch bigger. Not much different, but doesn't help. I"m going to swap pulleys. I"m also looking for a slightly longer belt.
Don
Old Jul 30, 2023 | 11:35 PM
rumm5's Avatar
Default fixed
Hi all;
Final update. Got the belt on. That slight difference in diameter was enough. Got belt on with little effort. When getting rebuilt alternators, watch out for what pulley is on it.
Don
Old Jul 31, 2023 | 06:26 AM
Jon89's Avatar
Best to have your factory alternator refurbished with the proper Denso kit rather than take a chance on an aftermarket one. I did that in July 2018 and no charging issues since. Replaced the factory serpentine belt at the same time....
Old Jul 31, 2023 | 01:14 PM
rumm5's Avatar
Default not done yet.
started car. only ran for a few seconds. remembered to reattach air box. started and ran fine for a minute, then check engine light comes on, tach fluctuates, trans error lights up, then restricted performance. Then it stalls. WTF?What did i do?
Old Jul 31, 2023 | 02:14 PM
michaelh's Avatar
Any chance the symptoms are like this?:
https://www.jaguarforums.com/forum/x...90/#post714167
Old Aug 1, 2023 | 01:48 AM
rumm5's Avatar
Default alternator symptoms.
As it happens, yes.I put a new regulator in this unit. It seemed a simple install, I'm wondering if i didn't hook up something right.
Old Aug 2, 2023 | 01:25 PM
rumm5's Avatar
i disconnected battery. Next day hooked up battery, ran ok except check engine light and variance in charging voltage. Maybe bad connection or bad regulator or brushes.I have spare rebuilt unit. I'll swap, see if it's better.
Mr rx-7 tt
Aug 9, 2021 03:08 AM
David F.
Jun 30, 2019 09:48 PM
RaceDiagnostics
Sep 12, 2016 04:39 PM
gogurt92
Nov 19, 2015 03:29 PM
YYC guy
Mar 2, 2012 07:18 PM
