Sirius Antenna location
Old Dec 27, 2013 | 08:57 AM
larueb's Avatar
Default Sirius Antenna location
I am installing a Sirius radio in my '99 XK8 convert today. Any input as the best place to place the antenna? I know what Sirius says but want real input.
Thanks!
LaRue
Old Dec 27, 2013 | 09:59 AM
I placed mine on the passenger side - just underneath the piece that covers the rear speaker panel - will see if I can find the pics or other thread that showed it. have not had any issues with it placed there.
adding link to other thread - see post 5 for pics of antenna location:
https://www.jaguarforums.com/forum/x...-radio-105153/
Old Dec 27, 2013 | 10:27 AM
awbj47's Avatar
I put mine next to the GPS antenna on the steel self under the carpet where the convertible stays when down. Remove rear seats, run your cable under armrest.If you XMtogo your done.Works great. I leaned this from our forum.
Old Dec 27, 2013 | 10:54 AM
WhiteXKR's Avatar
+1, works great here.
Old Nov 16, 2015 | 08:53 AM
captjsh's Avatar
I had my Sirius antenna on the rear deck behind the third light and it worked great. After reading this post I repositioned it to the shelf next to the GPS antenna to be more discrete. However, I did notice some degradation to the receptions and when the top is down even more skipping. I am wondering if there is a better antenna out there or which one is everyone using? I am attaching the one I am using.
Old Nov 18, 2015 | 09:07 AM
vettegood's Avatar
Hello, my installer (top-notch) placed the antenna on the outside on the drivers side windshield. Says "the best reception comes when antenna on the outside of car and on glass rather than metal".
Happy Motoring and listening...
Old Nov 23, 2015 | 11:17 AM
captjsh's Avatar
I have found a new place for the Sat Antenna that gets good reception and is out of sight. It is in the third brake light. You must remove the outer housing from the antenna with 4 Torx screws on the underside to make it fit. To snake the wire with the light wire, you must cut off the connector. You can re-splice the coax cable later. Apply a little silicone or dish soap to push it through the wire loom at the hinge to enter the trunk space.
Old Nov 23, 2015 | 01:50 PM
BlkCat's Avatar
Same here. Works fine.
Jack
oldjaglover
Dec 25, 2024 04:33 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
philwarner
Jan 31, 2016 09:36 AM
jorgef858
Jan 14, 2016 11:32 AM
