Something Exploded
Old Oct 20, 2013 | 02:44 PM
Lawrence A's Avatar
Default Something Exploded
While driving 60 mph on freeway I heard a loud burst under car on drivers side. There was a seam split on something and a lot of white residue all on underside of drivers side. Does anyone knows what happen? Thanks LA
Old Oct 20, 2013 | 03:41 PM
Lawrence A's Avatar
Default Added Pics
Old Oct 20, 2013 | 03:51 PM
ccfulton's Avatar
The only thing in the seat I could imaging bursting and making a noise might be the inflatable lumbar support.
Have you tried inflating or deflating it?
Old Oct 20, 2013 | 04:00 PM
ccfulton's Avatar
Sorry, I misunderstood. When you said seam I thought you meant something in the seat.
Did anything else happen when you hear the noise? Steering get heavy? Any warning lights come on? Low coolant message?
Old Oct 20, 2013 | 04:02 PM
Lawrence A's Avatar
Default Loud Bursting sound
See pics Charley, on outside and underneath left side of vehicle.
Thanks for reply...
Old Oct 20, 2013 | 04:42 PM
The Coupe's Avatar
You say that "a seam split on something." Can you be more specific, maybe with a better photo?
Seems more likely that you ran over something with liquid in it, rather than something exploding on the vehicle. We all know what liquids are on-board, and none of them are "white" on a properly sorted car.
Old Oct 20, 2013 | 05:06 PM
mike66's Avatar
Did a prior owner fill the rockers with illegal substance?
Old Oct 20, 2013 | 06:09 PM
Lawrence A's Avatar
Question
Is that what the split panel is the "rockers" and the residue is maybe something illegal?
The former owner lived in the LA area and car sent here for sale in 2007 with only 37,000 miles on it, maybe I should investigate more...Will take a closer picture and attach.
Old Oct 20, 2013 | 06:28 PM
plums's Avatar
That "plate" is a heatshield. Maybe there was a bag tucked behind it.
Your car just depreciated in value ... a lot
Old Oct 20, 2013 | 06:37 PM
mike66's Avatar
I'm not that familiar with the underside sheet metal, but no the rocker panels are the part under the door sills. Did you dare to give the white substance a taste? If you ran over something, it hit pretty hard. Nothing in there to blow up.
Old Oct 20, 2013 | 07:08 PM
Lawrence A's Avatar
Default Pop sound
As mention I was going about 60 mph heard a pop then a long sizzle, when look to see what happen all I saw was white residue all under and on the left bottom size of car, Will have my mechanic look at it this week. Will let you know Thursday the results, Thanks for all the replies. LA
Must of ran over spray paint can!!!
Old Oct 20, 2013 | 08:36 PM
ccfulton's Avatar
I backed over a bottle of car wax in the garage once and it exploded a lot like that. Harmless enough, but boy what a mess!
Old Oct 20, 2013 | 08:50 PM
Steve8's Avatar
I "nudged" a gallon can of leftover paint once backing out of garage. Never felt it, luckily saw the off-white pool spreading across floor as I backed out. Fortunate, so I could clean it up right away from floor, assorted mops and brooms, and most importantly the tire, before it could fling it op onto to car driving off. Spray can theory sounds good to me.
Good luck to you cleaning it all up. But that panel, or heat shield, how would it get bent up like that? Could it have been that way before?
Steve
Old Oct 20, 2013 | 10:35 PM
mike66's Avatar
Originally Posted by Steve8
I "nudged" a gallon can of leftover paint once backing out of garage. Never felt it, luckily saw the off-white pool spreading across floor as I backed out. Fortunate, so I could clean it up right away from floor, assorted mops and brooms, and most importantly the tire, before it could fling it op onto to car driving off. Steve
Ouch! reminds me of the time I had the old o-ring still on the oil filter housing when I did an oil change and ended up with 4 quarts on the driveway after backing up!
I'm sure we've all had our epic messes.
BrentGardner
29
Dec 16, 2024 12:13 AM
willtoliv
Oct 2, 2015 12:18 PM
amaezing
Sep 26, 2015 07:21 PM
leaperjag
Aug 17, 2012 10:06 AM
maikal_0011
Dec 8, 2010 06:38 PM
