Spark plugs.
Old Jul 20, 2022 | 03:59 AM
JagV8's Avatar
Originally Posted by 73MustangBill
From the Jaguar workshop manual for the 2003 to 2006 XK8
Normal Maintenance Not necessary. Filled for life.
Severe Duty Maintenance Change the fluid at 48,000 km (30,000 miles) intervals.
I'm not sure when it was changed but my notes imply I saw it in 2009.
Of course, it IS filled for life - choose how "life" is defined, though...
Old Jul 20, 2022 | 07:05 AM
JayJagJay's Avatar
NOTES!?
No kidding, Man... I wanna be just like you!
Old Jul 20, 2022 | 11:45 AM
zray's Avatar
the longer one leaves the fluid unchanged, the shorter the transmission’s life will be. Everyone seems to be in agreement on that point.
Z
As similarly noted by JayJagJay, I’m duly impressed by your note taking (and finding said note 13 years later !!). If only you were taking notes for me, my life would have direction and meaning
Z
Old Jul 20, 2022 | 12:16 PM
JayJagJay's Avatar
Hmm...
Thing about the fluid change (say after 9yrs, or 16, or 160miles,,, is that the adaptions have adapted, over the course of thoooousands of miles to, yes, the normal wear of the trans (etc) - but also to the properties of the fluid...
Have folks noted or noticed a "shocked" transmission (in terms of adaptions) after a fluid change?
I ask because - in all reality I've never went from a car that I am used/accustomed to. One was after an engine/trans swap (5hp to 5hp) and the other was a car where the trans was FULL of water - where I changed soft parts, solenoids, separator plate and,,,, fluid. I have no point of reference
Old Jul 20, 2022 | 12:23 PM
zray's Avatar
There’s no easy way to drain all the ATF from my ‘02 XKR without disconnecting the lines, no torque converter drain plug either, afaik. So I just drain the trans sump and change out 4 quarts at a time. After 3 or 4 sessions like that over time, I’m approaching nearly all new fluid.
So no “shocking” the transmission with all new fluid. But the transmission shops I’ve seen have had no issues with their 100% fluid replacements.
Z
Old Jul 20, 2022 | 12:41 PM
JayJagJay's Avatar
Z
Right on! Good to know
Old Jul 20, 2022 | 01:04 PM
Jon89's Avatar
Fresh ATF is always a good idea in these old cars....
Old Jul 20, 2022 | 01:14 PM
  #28
motorcarman's Avatar
I thought the thread title was "Spark Plugs".
Old Jul 20, 2022 | 01:33 PM
Jon89's Avatar
Yep, it is. But good advice is good advice regardless of the thread's title...
Old Jul 20, 2022 | 02:36 PM
  #30
zray's Avatar
I thought the tread title was "Spark Plugs".
I do understand the idea behind keeping a thread on topic.
On the other hand, if every off tangent comment, remark, or question, got its own thread, then there would be at least a 20 fold increase in thread titles. A bit too much to keep up with easily.
Z
Old Jul 22, 2022 | 03:32 PM
  #31
JagV8's Avatar
I just dump things in one long text file. Easily searched. Very crude.
(It does have some sections, e.g. one long chunk for the ZF, but properly organised it isn't!)
Old Jul 22, 2022 | 06:40 PM
  #32
73MustangBill's Avatar
I use an Excel spreadsheet to track when I do stuff. current fleet is 5 cars, plus mower, generator, and yard equipment, down from 6 cars and a boat as well. I do monthly checks of battery cranking amps, tire pressure, fluid levels, etc. Routine battery checks has revealed batteries going bad, so that is GREAT. I'd rather change it in my garage then out in some parking lot.
For my next trick, I'm going to incorporate the maintenance schedules into my Excel workbook, so that it can tell me when stuff is coming due. I'll post that when I finish with it.
Old Jul 24, 2022 | 02:46 PM
  #33
ozguy's Avatar
I'm in the process of changing my plugs so this thread has been great.
2 questions:
  • What grease do you recommend for the plugs? Straight anti seize?, or one with copper in it as I've others recommend?
  • How the heck do you remove the rubber shroud on a USA 2011 XF 5.0L on the passenger side? Seems caught tight between the last plug coil (closest to firewall, and the engine bay side wall), and I can't get it off for the life of me.
Thanks in advance for any guidance gurus.
Old Jul 24, 2022 | 02:49 PM
  #34
ozguy's Avatar
2 questions:
I mean the rubber shroud covering the cylinder head and coils).
Old Jul 24, 2022 | 03:32 PM
  #35
zray's Avatar
I use the tiniest line of copper anti seize on the plug threads. As already pointed out, the use of any anti seize will skew the torque numbers and you will over-torque the plugs if you use the factory torque recommendations with any anti seize.
that said l, if you’ve good experience for tightening the plugs by feel, then a very thin line of copper anti seize won’t get you into trouble. Don’t use more than a line the width of a paper clip wire. It doesn’t take much to get the threads some insurance.
and if you go by the book, you don’t even need any anti seize with new plugs.
above all, remove and replace spark plugs only on stone cold engines.
Z
Old Jul 24, 2022 | 03:35 PM
  #36
You are about to start another war, asking what to put on the spark plugs. NGK recommend NO ANTI-SEIZE on their plugs, as there is a compound on them already to act as an anti-seize. NGK claims that using an anti-seize allows you to overtorque the plugs by up to 20%, making them difficult to remove the next time they have to come out.
Old Jul 24, 2022 | 09:46 PM
  #37
oldmots's Avatar
Adding anti seize is not going to affect torque value to any critical degree. If you notice, the plugs are coated with a film of oil when they are pulled, meaning the head threads are also oil coated. The anti seize will be lost in translation. Even if you are worried, 20% of 18 ft lbs is 3.6 ft lbs, nothing.
Old Nov 24, 2024 | 11:15 AM
  #38
Jmitch's Avatar
Thanks for all the information. I have bout two hours of work, before I can try to start it after replacing both head gaskets. Hoping everything goes somewhat good…
Stu Jags
XJ XJ12 ( X305 )
Mar 19, 2023 11:40 PM
haggis95
Sep 23, 2018 06:43 PM
newuser
Mar 21, 2010 04:25 PM
wnlewis
Aug 6, 2009 09:16 PM
