Steering Wheel Issue
Old Jun 6, 2023 | 10:34 AM
Phil m's Avatar
Default Steering Wheel Issue
Hi All,
My project keeps on giving. My horn has never worked plus the airbag light keeps flashing so as the existing steering wheel was in a bad state I thought I'd change it anyway which might even deal with the issues but I'm not that lucky.
The horn is still not working.
Airbag only flashes when I push the airbag/horn.
As the fuses are all good and the connectors to the steering wheel were fine I'm guessing it could be a lose connection with the connectors themselves, does anyone know how to check these?
Has anyone ever had the same issue?
Any advice would be appreciated.
Old Jun 6, 2023 | 01:07 PM
Johnken's Avatar
I believe the air bag indicator always flashes to deliver a numerical code. 3 flashes (3) pause one flash (1). Look up air bag code 31 in that ironically my) case. Light repeats a couple of times then goes solid on.
Can you get a handle on the trouble code flashed?
John
Old Jun 8, 2023 | 08:56 AM
Phil m's Avatar
Thanks for the reply John.
I had to charge the battery which is the reason for the delay in my reply but now the light is not flashing it just a solid light, any ideas what this means?
Also has anyone had the same issue with the horn not working?
Old Jun 8, 2023 | 09:55 AM
Johnken's Avatar
Gosh, you got me. I thought they always flashed a trouble code b4 going solid.
J
Old Jun 8, 2023 | 10:05 AM
Johnken's Avatar
Look up TSB 3501-09
Might help even though is an XJ TSB
John
Old Jun 8, 2023 | 11:40 AM
Phil m's Avatar
Originally Posted by Johnken
Look up TSB 3501-09
John
When I first changed the steering wheel it only flashed when you tried to use the horn but since I gave the battery a good charge its now just a sold light. 😞
Old Jun 8, 2023 | 02:48 PM
Phil m's Avatar
I found this link which lists the error codes for the airbag which others might find interesting.
https://www.jaguarforums.com/forum/x...g-codes-39056/
I'm guessing I need to count the flashes on start up?
Old Jun 8, 2023 | 05:16 PM
michaelh's Avatar
For horn operation, check fuses #11 and #13 (both 10A) in the engine compartment fusebox. If they're good, check the horn relay (in the same location) either by substitution or bridging pins 3 & 5. That will confirm everything downstream of the BPM.
Old Jun 9, 2023 | 07:44 AM
Phil m's Avatar
Thanks for the advice Michael. The fuses are good so I'll check the relay when I go to the car later.
Old Jun 9, 2023 | 08:39 AM
Phil m's Avatar
Johnken - the flashing goes 2-2-3-2-3-2-3-2-3-2-1 =.27 but no 27 on the link above or is it 22? (drivers Side Airbag circuit fault)
Also I cant find TSB 3501-09 do you have a copy you could attach?
Michael- I changed the horn reply with a number already in the car plus a spare I have but no luck, do you know anything else I can try?
thanks again for your help.
Old Jun 9, 2023 | 10:17 AM
michaelh's Avatar
I'm trying to establish if the horns are actually working, or if they're just not being fired. Suggest bridging 3 & 5 on the relay socket, but I wonder... can you set the alarm off? Lock with the fob, unlock with the key, open the door and wait a few seconds.
You should hear the 'countdown' beeps from the steering column loudspeaker. Have the fob/key ready to cancel the alarm when it goes off. If you do hear the horns, then the issue is upstream of the BPM or, less likely, the BPM itself.
Old Jun 9, 2023 | 05:24 PM
Phil m's Avatar
Unfortunately Michael my fobs aren't working either and never have really which is another issue so I cant try as advised, now and again the passenger door locks and unlocks repeatedly but that's all when I press the button.
the car is a challenge. 😄
Old Jun 9, 2023 | 05:28 PM
michaelh's Avatar
Doesn't your car go into 'countdown' mode when you unlock with the key?
Old Jun 9, 2023 | 05:43 PM
Phil m's Avatar
To be honest I don't know what the countdown mode is, I lock it using the key and the lights flash which I assume is shutting down the car?
Old Jun 9, 2023 | 05:48 PM
michaelh's Avatar
That's just what I call it - the handbook calls it a ticking noise.
I've attached the Security System literature - have a look at the 'Key Operation' section.
Old Jun 10, 2023 | 07:45 AM
Phil m's Avatar
That's a really interesting read to be fair Michael. The car does tick/go in to count down mode.
HBZ
Feb 6, 2019 04:43 PM
Scottish Chap
Jan 8, 2018 07:06 PM
scarbro2011
Oct 18, 2015 11:40 AM
ianb
Oct 24, 2012 04:58 AM
Mr. Tony
Feb 15, 2011 05:58 AM
