Steering wheel memory 1999 XK8
Old Mar 12, 2007 | 03:40 PM
Yurikaze's Avatar
Default RE: Steering wheel memory 1999 XK8
Wow. So does mine.
This appears to be a common problem.
Old Apr 29, 2008 | 10:57 PM
hlgeorge's Avatar
I know this thread is about a year old, but my 2001 XKR is doing the same thing. Does anyone have a remedy? Is this a memory module issue?
Old Apr 29, 2008 | 11:16 PM
mlewisfwa's Avatar
I can't answer your question but I can tell you my '97 XK8 w/48k miles does the same thing. The dealer records show that they replaced the steering column motor twise...
Good luck finding the answer, we all will be very interested in the fix.....
Old Apr 30, 2008 | 04:48 AM
Campeon's Avatar
Add my '04 XKR to the list. It works about 80 percent of the time but when I do have to do it manually, I get that "moves a half inch then hesitates" issue too.
Old Apr 30, 2008 | 06:45 AM
test point's Avatar
Another one of Jaguar's several common problems. The steering wheel position potentiometers and lubrication of the moving parts are the problem. I suspect that the lube problem agravates the burning of a resistance spot on the pots. Many discussions on the subject with the only solution to replace the motor/potentiometers.
Old Apr 30, 2008 | 12:15 PM
hlgeorge's Avatar
According to my owner's manual the hesitation on steering wheel movement is a safety factor when the gear lever is out of the park position. It should not move continuously while the car is in motion. Same for the memory seat feature; it will not function unless the shifter is in the park position. Albeit, mine does not work half the time in park. I have the memory buttons 1 & 2 set for the same position. When button 1 does not work, I press button 2, then button 1 again and it might work. Lincoln (Ford) products use the same features. I wonder if they are having the same issues. At least the steering wheel always raises up when the key is removed from the ignition.
Old Apr 30, 2008 | 05:14 PM
test point's Avatar
When I first addressed the problem I set Memory 1 and 2 on either side of the stop spot. Then alternated 1/2/1/2/etc about a hundred times. That helped with the percent fail but did not resolve the issue.
It's just another thing to love about these cars.
Old May 1, 2008 | 05:23 PM
test point's Avatar
It is intregrated as far as the parts counter is concerned.
H20boy
Dec 24, 2024 03:23 PM
99xk8guy
May 28, 2024 09:36 PM
PMKimpton
Aug 3, 2019 08:22 PM
Armor6
Sep 14, 2015 07:56 PM
jimmiejag
Sep 9, 2015 02:56 PM
