Strange door latch issue
Old Jan 31, 2013 | 06:42 AM
kench's Avatar
Default Strange door latch issue
So twice today my driver's side door wouldn't close all the way unless I lowered the window. Then, voila, it closes nice and tight. Kind of a pain to have to go around to the passenger side to put up the driver's side window and remove the key though!
I don't get any warning lights, so I don't think it has anything to do with the microswitch, but I could be wrong!
What do you think?
HK
Old Jan 31, 2013 | 07:41 AM
test point's Avatar
I think your window memory has lost its position location.
First thing to try is to run the window all the way down and hold the button for an extra 5 or so seconds until you hear a 'click'. Don't hear a click, just hold it a couple more seconds to be sure. Then repeat the process all the way up. The problem is usually caused by the battery voltage dipping below the electronics minimum threshold of about 10v. Because the window motors draw a lot of current this can easily happen on a weak battery.
Old Jan 31, 2013 | 07:45 AM
oldmots's Avatar
This is probably caused by the window losing its programming. Just start the car, run the window all the way down, then run it back up and hold the switch up for 5 seconds after it has stopped. if this doesn't fix it, you may need a new latch unit. It contains a microswitch that tells the body processor that the door is shut.
Old Jan 31, 2013 | 07:58 AM
Lost memory for the limit switches ............. unless you can't shut the door with the top down?
Old Jan 31, 2013 | 08:51 AM
steveinfrance's Avatar
New battery time....
Old Jan 31, 2013 | 03:01 PM
kench's Avatar
Surprise, surprise, I reset the window, and now the door shuts.
I would have swore that the window position wasn't the issue.
It really sounded like a metal on metal clunk when the door would fail to shut.
Thanks for the input!
HK
Old Jan 31, 2013 | 03:06 PM
WhiteXKR's Avatar
Now if it recurs again in short order you have a battery issue.
Old Jan 31, 2013 | 04:09 PM
gwagner's Avatar
Originally Posted by GGG
+1
What I always find puzzling when I hear about this problem is why doesn't the window controller use nonvolatile memory to store these settings? The ECU and TCM clearly store their parameters over low voltage and power outage situations.
Old Jan 31, 2013 | 05:38 PM
Don't grumble:
1. it's the best warning of a possible failing battery
2. if it was stored, you'd end up going to the dealer for a window reset
99xk8guy
Sep 29, 2025 10:51 PM
Wolfy
May 28, 2024 08:06 AM
Dz1rfj
Jul 17, 2018 10:29 AM
Raul Lara
Sep 14, 2015 07:31 PM
Raul Lara
Sep 2, 2015 05:23 PM
