Stuck Purge Valve?
Old Dec 5, 2007 | 07:09 PM
jag_genius's Avatar
Default RE: Stuck Purge Valve?
90% of the time it is a canister close valve. it's off the right side carbon canister. usually a proper smoke test, at a jag dealership.. can easily pin point the leak.
Old Dec 5, 2007 | 07:27 PM
Max's Avatar
Max
Had the same problem two years ago. The cannister valve was $71.22 with 1.5 hours of dealership labor for $133.50 = $204.72 w/o tax. Will probably be a bit higher for the part now.
Old Dec 7, 2007 | 07:04 PM
jag_genius's Avatar
no problem..first jag
Old Dec 11, 2007 | 09:41 AM
ken@britishparts.com's Avatar
Just for giggles, see if they will warranty the cap. That's the most common problem and they can't make all of them exactly perfect.
Old Dec 11, 2007 | 01:01 PM
Wow! That's a head scratcher. Purge valve makes sense. The ECM is an expensive guess.
Old Dec 11, 2007 | 06:39 PM
jag_genius's Avatar
when you smoke test the system ... if the purge valve is stuck open the smoke will come out the airfilter...
when you replace the close valve your sappose to check the actual vent and and pipe for corrosion.. if it is corroded then rust can fall back into the new valve and keep it from sealing..which will give you p0455 evap gross leak. again.. definitly not the ecm..
Ragn0r
Sep 29, 2015 10:38 AM
jjmiah217
Sep 28, 2015 09:09 AM
