Throttle Position sensor
Old Aug 1, 2022 | 07:43 AM
TGraves's Avatar
Default Throttle Position sensor
I was wondering about my TPS, and Googled it. I found many types and prices, even reworked sensors. What is the skinny? Are some knock-offs that aren't worth shipping?
I read the Denso is a direct replacement and cheaper parts only have one resistance strip. Any recommendations? I hate spending more than is really necessary.
Old Aug 1, 2022 | 09:37 PM
zray's Avatar
in Denso we trust.
this forum is full of woeful tales of electrical failures that were caused by using cheap(er) parts, cheaper than Denso.
Some of the OEM Denso parts are no longer available. But if you can find genuine Denso parts you are better off paying more now, instead of much more later.
Z
Old Aug 3, 2022 | 03:03 PM
kingst435's Avatar
2013 XKR had windshield repaired and then when I picked up car the exhaust sounded horrible (quiet) and accelerator seems sluggish
Old Aug 4, 2022 | 09:39 AM
TGraves's Avatar
Default Crestfallen..
Originally Posted by zray
in Denso we trust.
Z
I don't get a good feeling about this...
Old Aug 4, 2022 | 10:19 AM
michaelh's Avatar
Are you seeing a DTC?
I've attached TSB 303-58 that may apply.
The TPS part # is DENSO 198500 - 3250, I think.
edit: added 303-S498
Old Aug 5, 2022 | 06:07 AM
Here's a thread from when I had a 2001 XK8 with TPS issues. Steve (steveinfrance) dismantled my TB to determine the cause of failure.
https://www.jaguarforums.com/forum/x...acement-77560/
Interesting to see how little it takes to stop the TPS working.
Old Aug 5, 2022 | 06:38 AM
TGraves's Avatar
Default Correct TPS
No, but I'm checking all sensors on my car and like to be prepared somewhat because I have questions on cars at 100k mi.
Old Aug 6, 2022 | 12:04 PM
TGraves's Avatar
Default TPS vulnerability
Actually, considering how many times one moves in 100k mi, I think they are pretty tough.
My concern is availability of a replacement.
Old Aug 7, 2022 | 07:10 AM
xalty's Avatar
just buy it off amazon and give it a try
Old Aug 8, 2022 | 07:55 AM
TGraves's Avatar
Default Dice roll on TPS!
About all you can do unless you want to gamble on a used Throttle Body.
I have some experience and equipment to work on surface mount electronics. If I could get a bad unit, I'd try a repair on one.
prodigy215
Dec 28, 2022 11:23 AM
thom4782
Aug 2, 2021 05:46 PM
fredd60
Oct 21, 2019 07:46 PM
bonzai
Feb 5, 2015 03:50 PM
N224WR
Apr 1, 2011 12:30 AM
