Top Fluid
This link might help JagRepair.com - Jaguar Repair Information Resource At the bottom you will see a syringe that you can use to add and or remove fluid. I hope this helps.
You've got prompt replies from two of the most knowledgeable members on the forum.
Please follow this link to the New Member Area - Intro a MUST New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum and post an introduction about yourself and your vehicle for all members to see.
Welcome to the forum Tonto,
In order to remove the fluid from the hoses, latch & rams you will need to empty the tank and fill with new and run your roof system a few times then drain and refill again. Do this process a few times and you will be done with the purge. This system is a closed system and operating it a few times will mix the old with the new and replace the fluid in the latch and rams. The latch and rams are a push/push system and at no time does the fluid to close touch the fluid to open. I should also mention if you remove the pump from the rack do not pinch or bend the hoses and if you elect to remove the hoses mark them. It is critical to the operation to get the hoses reinstalled correctly.
So my spouse broke her leg and I am just getting back to this. Took it to the dealer and mentioned yellow vs green fluid and they didn't know what I was talking about and said all fluids are compatable and their reference calls for CHF11S. I didn"t let them touch it. What is the truth?
Unless it was changed, your '97 car has the old yellow UNIVIS fluid. It should be removed and the updated CHF11S should be added.
aholbro1
Dec 29, 2024 06:46 PM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
Oct 12, 2015 11:56 AM
abonano
25
Sep 25, 2015 10:43 AM
chatmanx
Sep 11, 2015 07:17 PM
