Torque converter drain pluc
Old Apr 15, 2011 | 02:12 PM
Lifts's Avatar
Default Torque converter drain pluc
does anyone know drain plug in the torque converter of a 2000 xkr?
i have to replace the electrical connector bushing in the transmission and this would be a good time to chance the fluid. does anyone know if there is a drain plug in the torque converter of a 2000 xkr with a mercedes mod 722.6 transmission
thanks in advance
Old Apr 16, 2011 | 12:42 AM
avos's Avatar
only the 1998 versions have one, from 1999 there is no drain plug anymore.
Old Apr 16, 2011 | 08:18 AM
motorcarman's Avatar
I did the trans service on a local member's 2000 MY XKR and the drain plug was in the torque converter. I got nearly 10 liters of JLM20292 fluid back in the W5A580.
I don't know when the drain was deleted.
bob gauff
Old Apr 16, 2011 | 11:13 AM
David's XKR's Avatar
I just had this service done including the connector. I researched this drain plug issue. Most everyone says there's no drain plug on the 2000 XKR. But I did find a few people that said they had found one and used it. The guy that did mine said there was no plug. Don't pay a lot for the electrical connector. The dealer said $75.00 for the part. The exact same part is available for under $10.00 on most internet sites or at german auto parts stores or even Dodge dealers. That transmission is in a lot of cars.
Old Apr 17, 2011 | 02:16 PM
LedZepplin's Avatar
Default tranny plug
I changed my tranny fluid a year ago (2001 XKR 722.6 box and 50K miles) and found no drain plug. Which is a pain as you can only get about 4-5qts out. So as I bought a case of 12Qts fluid on amazon for $60 and cycled the fluid 3 times. I also changed the elec connector and filter. I was lucky as I had the cat converters out to change all O2 sensors so replacing the elec connector was easy.
Old Apr 17, 2011 | 07:06 PM
Mish_Mish's Avatar
Traditionally MB had drain plug in torque converter, so chances are W5A580 should have one. I am planning to drain generic ATF+4 that I replaced in 4 drain and refills via transmission pan. So this time I will try to find torque converter drain and let you know. I have 8 qts of Amsoil fluid that I want to use as permanent.
Old Apr 18, 2011 | 12:13 AM
avos's Avatar
@Bob,
I also don't know the exact cutoff date, it was somewhere in 1999, could even be mid to late 1999. I know of 2 1999 models that didn't have it anymore (forgot to note the vins).
You are the first one mentioning a 2000 model still has one, what was the vin number, and re you sure it wasn't a replacement TC ?
Old Apr 18, 2011 | 06:29 AM
test point's Avatar
Also note that the model year can be different in Europe and the US. A '99 in GB may well be a '00 in the US. That's why you can see a car manufactured in April listed as the next MY over here.
aholbro1
Dec 29, 2024 06:46 PM
mrplow58
Jan 21, 2024 05:53 AM
Jagfastic
Sep 14, 2015 07:41 PM
chatmanx
Sep 11, 2015 07:17 PM
obwoodie
Sep 3, 2015 07:45 PM
