Type (BRANDS) of coolant can I use?
Old May 19, 2012 | 01:35 AM
Billyk's Avatar
Post Type (BRANDS) of coolant can I use?
For my 2000 XKR, I am wondering if anyone can tell me what type (BRANDS) of coolant can I use to top off my car? My "Engine Coolant Low" message appeared today along with the "Performance Restriction" message a few minutes later. Any help is greatly appreciated. I'm fairly new to this forum. Thanks!
Old May 19, 2012 | 04:52 AM
I understand it would be easier to just pick up a particular BRAND but you need to check for the coolant SPECIFICATION.
Brands can cover a range of specifications, some of which are suitable for your XKR and some aren't. What you're after is:
Orange Extended Life Coolant conforming to WSS M97B44-D
This information will be on the label.
One BRAND that markets this specification in the US is PRESTONE'S Orange "5/150 Extended Life AntiFreeze".
Old May 19, 2012 | 01:41 PM
Jon89's Avatar
Graham gave you excellent advice. Go with orange-colored coolant that meets the M97B44-D spec, and you'll be good to go....
Old May 19, 2012 | 05:57 PM
artstar's Avatar
I got the same message, low coolant, a month after I got my 01. I went and got Dexron and have had no problems since, it really was just low no leaks either. I think it had sat at the dealer for a while.
Old May 19, 2012 | 07:02 PM
Beav's Avatar
Uh... Dexron is automatic transmission fluid. I think you meant Dexcool.
Old May 19, 2012 | 07:41 PM
artstar's Avatar
yes, I knew it was some "dex".
Old May 19, 2012 | 07:50 PM
Well "Dex knows"!
Old May 19, 2012 | 08:31 PM
Cerberus66's Avatar
It seems on the landy forum they rec anything BUT dexcool.
Old May 19, 2012 | 09:39 PM
Beav's Avatar
I've said it before, I don't like Dexcool, but it is the specified coolant.
Old May 20, 2012 | 02:46 AM
plums's Avatar
Perhaps. But, on a car that has an original spec of Dexcool, then the safest thing for an inexperienced person is to stick with it. It is the only responsible answer to someone whose experience level forces them to even ask the question.
Changing coolant types is an exercise for the experienced who understand the reasons, the risks, the consequences, the required precautions, and the required procedures.
The same caveat applies to any change from original spec coolant type to some other coolant type.
Old May 20, 2012 | 07:29 AM
ccfulton's Avatar
Somewhat off topic, but why do people hate DexCool so much?
Old May 20, 2012 | 11:38 AM
Jon89's Avatar
Some folks believe that Dexcool degrades fittings and hoses. I've used it in our 2004 Lexus RX330 AWD SUV for years with no problems whatsoever....
Old May 21, 2012 | 01:12 AM
Billyk's Avatar
Thank you everyone for your advise and helpful information.
Old May 21, 2012 | 06:45 PM
Beav's Avatar
It just seems, to me, to seep past nearly every connection and leave a crusty mess. Also, again it seems to me, that plastic parts in a DexCool system seem to disintegrate (or at least more quickly) while other coolants don't seem to have that particular issue. I've not seen everything but I have seen a lot over the past forty-two years and these are just my non-documented perceptions.
Old May 21, 2012 | 07:27 PM
plums's Avatar
Actually, the Glysantin formulations like Xerex G-05 also leave white stains unless wiped off immediately. Note to readers, Xerex G-05 is *not* a dexcool equivalent. Just discussing staining.
way2far
Aug 31, 2022 09:26 AM
prettydaim
Mar 28, 2021 07:47 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Raul Lara
Sep 14, 2015 07:31 PM
dcvickers
Sep 2, 2015 06:14 PM
