Vacuum gauge
Old Feb 16, 2026 | 12:30 PM
alatoni14's Avatar
Default Vacuum gauge
I decided to install a gauge works as it should
added pucture car running
Old Feb 17, 2026 | 08:44 AM
Warmuthb's Avatar
Looks low to me. Assuming you’re at near sea level and engine is at idle. Would think 15-20 would be more “normal”?
Just a thought.
Brian W.
Old Feb 17, 2026 | 10:42 AM
alatoni14's Avatar
Just a thought.
Brian W.
that pic was with ignition swith on was going down you are correct i am around 14,15
thanks
Old Feb 17, 2026 | 10:47 AM
Pistnbroke's Avatar
You will find the reading is very low 15 in Hg compared to a less tuned car at twice theat figure.
This is why the brakes are so poor and feel soft. I fitted an electric vacuum pump and the brake teste readings went from 150 to 300 with a hard pedal.
Search my posts and its all documented its called "The Route to Good Brakes"
Old Feb 17, 2026 | 11:11 AM
alatoni14's Avatar
Default Vacuum
Just a thought.
Brian W.
I decided to check was cropping up tours 20
Old Feb 17, 2026 | 03:36 PM
zray's Avatar
Plumbing photos ?
Z
Old Feb 17, 2026 | 04:43 PM
alatoni14's Avatar
Originally Posted by zray
Plumbing photos ?
Z
there's a rubber groomer behind wiper to feed the line i tap in to a vacuum line.front passenger side SC BY the big Hex air bleeding valve
Old Feb 17, 2026 | 05:35 PM
zray's Avatar
where and / or how did you come thru the firewall ?
Z
Old Feb 17, 2026 | 07:15 PM
alatoni14's Avatar
Z
driver side behind the wiper you will see a rubber groomer make a small slice feed small thin rid it will show u0 by the footwell against the lower kick panel
Old Feb 17, 2026 | 08:55 PM
LMG's Avatar
LMG
JagWrangler's instructions for installing his RealGauge conversion includes details with photos on how to snake wires (or hoses) through the firewall: https://www.thejagwrangler.com/uploa...on_rev_1.1.pdf
I followed those when I installed my oil pressure gauge:
Old Feb 18, 2026 | 02:32 AM
Pistnbroke's Avatar
Firewall. .Yes that is a problem. You only have the live to take to the brake light relay in the Trunk. I drilled a small hole to the right ( car right ) and came out near the pedals. The RHD if totally different in the Servo area but you may get a wire through with the Hood release.
Quadcammer
Dec 19, 2022 06:09 AM
WatchGuy
Oct 27, 2022 09:02 PM
domino_z
Apr 6, 2017 07:53 PM
Thomasso
Jan 3, 2012 08:08 PM
carlorner
Jun 8, 2011 05:05 PM
