Valley Hose Alternatives
Old May 27, 2014 | 01:42 PM
Rezzz's Avatar
Question Valley Hose Alternatives
Anyone have any suggestions regarding alternatives for the valley hoses. The silicone ones appear to be to hard to get priced and delivered to the US or Canada in a timely manner and I need to put my engine back together within the next week.
Old May 27, 2014 | 01:52 PM
Fulton's Avatar
I ran into the same issue Rezzz. I ended up using the OEM hoses. I figured they lasted 15 years, long enough for me to forget what a P.I.A. job it was to change them.
Old May 27, 2014 | 01:58 PM
jonscot's Avatar
I'm awaiting delivery of my OEM versions as well, and was considering looking at the hotrod catalogs for some silicone alternatives...just received JEGs today in the mail.
Old May 27, 2014 | 02:11 PM
dieseldoc's Avatar
I agree with Fulton, oem lasted that long, who knows what the future holds in store.
Old May 27, 2014 | 03:33 PM
franksm's Avatar
I just put some straight pipe in there (19mm I think), pressure tested it, and it's worked fine for nearly a year now
Attached Thumbnails Valley Hose Alternatives-img_2033_zps2b3d0495.jpg   Valley Hose Alternatives-img_2035_zps830618e9.jpg   Valley Hose Alternatives-img_2034_zps9a0b5f4e.jpg
Old May 27, 2014 | 03:48 PM
The Coupe's Avatar
Originally Posted by franksm
Ah, the bloody bit of paper towel after a job completed. Wouldn't know how to do it any other way!
Old May 27, 2014 | 11:15 PM
aode06's Avatar
Its very important to remove ALL scale , rust and corrosion from the nipples the hoses go on to, then give them a smear of black rtv around the CLEAN nipple, same for the nipples on the Throttle body coolant lines, those hoses will probably be full of rust scale..
The newer hoses are redesigned and tougher, no need to worry about that happening again, probably for as long as you own the car.
Old May 28, 2014 | 07:08 AM
Rezzz's Avatar
Just want to get this right. When you mean the newer hoses do you mean the ones direct from the dealer? SNG? We have so much off shore junk in my neck of the woods anymore I hate buying anything off the shelf
Old May 28, 2014 | 07:13 AM
aode06's Avatar
The hoses from any supplier. The material and manufacturing process of these hoses from when our car was made, till now have changed drastically.
The standards for cooling hoses, oil hoses, and power steering hoses are held higher as of 2005.
I have a new coolant hose from 1998, and the same for toaday's date, they ARE NOT the same.The new hose has more 3 times more threadings, and 20%thicker,and sturdier.
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
mat32essex
Oct 3, 2015 04:12 PM
waynepaulj
Oct 2, 2015 04:05 PM
CaptainHam
Oct 1, 2015 02:01 AM
