Voltage Reading
Old Nov 27, 2011 | 07:34 AM
Alag's Avatar
Default Voltage Reading
Just put my meter on the fuse box terminal next to the shock absorber mount and it read 12.2v.Not been used since Friday is that normal after allowing for any loads?
Thanks Al
2002xkr 74000
Old Nov 27, 2011 | 07:53 AM
WhiteXKR's Avatar
It is probably best to check at the battery terminals, although with the car off there should be very little difference.
A battery in good condition should be at least 12.5...but a load test is a more reliable measure.
Old Nov 27, 2011 | 08:18 AM
Alag's Avatar
Thanks WhiteXKR read it again across the battery terminals now 12.1v although the trunk lights are on.Only had the car about 3weeks always starts first time.Perhaps needs a good run.Can you charge from that fuse box contact+ and earth on shock mount?
Thanks Al
Old Nov 27, 2011 | 08:32 AM
test point's Avatar
Yes, you can but you shouldn't try to jump start from another battery at that point.
Old Nov 27, 2011 | 08:39 AM
WhiteXKR's Avatar
If you charge it, it is safest for the electronics to charge it at both battery terminals directly with the ignition off. (Even safer with the battery disconnected from the vehicle, but you will need to reset the windows and on a UK car you will need to reset the radio code when you reconnect).
If it is starting fine, and all electrics in the car are working normally, just keep a watchful eye. Usually the first sign of battery trouble is when the windows do not automatically lower properly when openning the door and need to be reset (see the manual)...the electronics are very sensitive to low voltage in this car.
Old Nov 27, 2011 | 12:03 PM
scm's Avatar
scm
Originally Posted by WhiteXKR
Usually the first sign of battery trouble is when the windows do not automatically lower properly when openning the door ...
I thought the first sign of a low battery was ABS warnings during startup? That's what happened to me, anyway.
Old Nov 27, 2011 | 12:14 PM
WhiteXKR's Avatar
That is common also...I have seen both.
Old Nov 27, 2011 | 12:26 PM
Alag's Avatar
Thanks for your replies so far I have no warning lights showing will give it a run tomorrow and report back.
Al
Old Nov 28, 2011 | 09:27 AM
Alag's Avatar
Hi just reporting back.I tested the battery again this morning still 12.20v have since been a run and now reading 12.40v which is nearer the norm.I think I am right in saying that when a battery is reading 12v it is actually flat.So I will keep an eye on it.
Thank you for your guidance Al
hafren
23
Jan 3, 2025 11:26 AM
Sprayall
May 30, 2021 08:13 AM
CaneCounsel007
Nov 13, 2015 09:05 PM
eurotire
Sep 18, 2015 07:27 AM
Sprayall
Sep 3, 2015 07:49 PM
