Water pump questions
Old May 24, 2018 | 07:41 AM
Barry_Tucker's Avatar
Default Water pump questions
I am about to change my water pump. It looks easy since I have both rad hoses off and am about to change the serpentine belt as well, but I have a couple of questions:
1/ The manual says to "discard the pulley bolts" > Why on earth would you discard perfectly good bolts ? Does anybody have any insight on this ?
2/ When replacing the pump, the torque spec for the bolts says: "8 NM plus 90 degrees " This seems very low but I can't find any updated TSB or anything like that...again , any input is appreciated from those with experience.
When I get this done and refill the coolant I am ready for summer
Old May 24, 2018 | 08:55 AM
RJ237's Avatar
8 Nm converts to around 71 in.lb., which is correct. The fasteners are discarded because the additional 90 deg stretches the threads. I just reused with blue threadlock.
Old May 24, 2018 | 09:29 AM
Johnken's Avatar
+1 with RJ. Don't worry those torque numbers work just fine Barry.
John
Old May 24, 2018 | 10:39 AM
Fair enough ...thanks
I will be reusing the pulley bolts as well. They are torqued to 10 NM....can't imagine that this puts enough strain on them to stretch them LoL
Old May 25, 2018 | 01:08 PM
Ophitoxaemia's Avatar
I had to buy a set of smaller sockets when I replaced my water pump. The heads are 8mm, tiny! Thus the low torque rating.
I didn't use a torque wrench, no leaks in 5 years and 30K miles.
The thermostat housing was a different story though!
Old May 25, 2018 | 01:54 PM
all done and torqued properly ...no leaks
Busa196
Jan 13, 2025 04:33 AM
sneal46
Jan 3, 2011 07:17 AM
Joe C
Nov 30, 2010 12:23 PM
AntixSD
Apr 3, 2010 07:40 AM
