What does 3w83 mean?
Old Jun 26, 2017 | 09:37 AM
Diddion's Avatar
Default What does 3w83 mean?
Is this a model or type number? It represents the first digits on the identification sticker in on the ongoing saga of the IC I am trying to source - but when I put it into Google, a whole lot of other components are thrown up.
Thanks, David
Old Jun 27, 2017 | 12:45 AM
woox4's Avatar
No idea but I do know that the Jaguar part numbers get better search results. Try these, depending on your velocity measurement unit of choice:
Old Jun 27, 2017 | 01:34 AM
Diddion's Avatar
Thanks, Chris. Do you have a link to that page, by any chance? I would like to follow down some of the submenus.
Old Jun 27, 2017 | 01:43 AM
woox4's Avatar
It's a snip from the Jag EPC, which I think you can download from the stickies. Jag classic parts has it on-line now as well though so try here: https://www.jaguarclassicparts.com/uk
Old Jun 27, 2017 | 02:49 AM
It's the first four digits in the manufacturer's (Visteon) part number. Here's the label on my 2005 XK8 Instrument Pack 3W83-10849-AG:
To check module compatability you need to refer to the VCATS label on your vehicle behind the liner in the luggage compartment. This is from my 2000 X308:
Once you have the module information, have a look at the TSB on compatibility and interchangeability:
TSB 418-03 Module Compatibility.pdf
There may be a later version of the TSB.
Old Jun 27, 2017 | 04:42 AM
Diddion's Avatar
Many thanks for the information and links, Chris and Graham. Graham - was the instrument pack from a coupe or convertible, and did your model have adaptive cruise control? According to Eurojag, most of the later models did have acc. the module in question has the same ID as your (and mine), though ending with the letters DG. My original one ended with the letters DF - the chap I spoke to at Eurojag says that these letters represent time, with the G meaning it is slightly later.
Incidentally, no VCATs label anywhere to be seen! I have stripped all the carpeting from the boot/trunk, and there are no labels behind it, despite a careful examination; I have not looked behind the rigid plastic moulding along the back. I don't suppose it would have been placed somewhere else?
Old Jun 27, 2017 | 01:39 PM
Originally Posted by Diddion
..... Graham - was the instrument pack from a coupe or convertible, and did your model have adaptive cruise control? .....
The IP in the photo was my 2005 XK8 4.2-S Coupe with ACC.
Old Jun 27, 2017 | 07:31 PM
woox4's Avatar
Try behind the spare wheel on the trunk floor for the label. That is where the TSB that Graham attached to his post says it is.
Old Jun 28, 2017 | 12:53 AM
Cambo's Avatar
I thought the VCATS compatibility was no longer an issue on the 4.2L cars?
In any case 3W83-10849-DF = C2N2456
C2N2456 has been replaced by C2N3091 https://www.jaguarclassicparts.com/uk/part/C2N2456
C2N3091 = 3W83-10849-DG
So either version will work, BUT it will need to be programmed to the car using WDS, IDS or SDD...
Just FYI, 3W83 is a designation of model and model year, in other words it's for an X103 XK8 or XKR.
The middle digits 10849 are for an instrument cluster.
The 2nd last letter is a feature type, the last letter is a revision.
