What's this thingy..
Old Aug 25, 2025 | 08:34 AM
Wafoo's Avatar
Default What's this thingy..
Only on the passenger side B pillar, looks like a speaker but ????
Old Aug 25, 2025 | 09:11 AM
MikeGriese's Avatar
If you are asking about the grille, it is a speaker cover.
Old Aug 25, 2025 | 10:22 AM
dibbit's Avatar
Its an ultrasonic transmitter-receiver for the airbag system - it detects if you have a passenger.
Old Aug 25, 2025 | 10:41 AM
pcolapacker's Avatar
Agreed.
Old Aug 25, 2025 | 10:48 AM
MikeGriese's Avatar
I stand corrected. Seems way simpler to just put a switch in the seat bottom.
Old Aug 26, 2025 | 01:12 AM
Einhead's Avatar
Be careful with theese "grilles"... its parts of a quite complicated aucustic sensor system that detects if you are sitting in the seat and if you are strapped in.
In the seat there are a pressure sensor that detects if you are sitting there. Underneith the seat cusion there is a flat bag with some kind of a silicone gel that when the bag gets compressed are pushing this gel towards a pressure swich.
The Pressure switch has two levels.
On the passengerside A-pillar there is also a little sensor that looks like a speakergrille.. same thing, a acoustic tranceiver.
On the center console in the roof, same thing.. a big grille with two tranceivers behind.
Then there is ofcourse switches in the seatbelt recepticles.
If you turn the ignition on and buckle up in the passenger seat, the little airbag light on the passenger dash (on the woodpanel) should be out. Lean forwad and the lamp should come on -Indicating that the airbag is disconnected, this is so you dont get whacked to DEATH if the airbag goes of with your head in the way.... that panel WILL smack you to kingdom come!
When the airbag sensing system does not detect anyone in the passenger seat, it also should disconnect the passenger airbag... to prevent the passenger airbag to go of if you have a small accident when alone in the car... So when you stumble out of the car, smacked in the face by the steering wheel airbag, inspecting your crashed car.. atleast you can comfort yourself with the fact that you dont have to pay for a new passenger airbag..
-I have a minor problem with this system, when alone in the car the dash airbag light goes out, but passenger side airbag light comes on indication that the pasenger airbag is off. If someone sits there it goes out again... So i beleive that the pressure sensor in the seat detects a small person there..
So be careful with thoose sensors.. if this system gets messed up... you are going to spend some time troubleshooting..
/E
Old Aug 26, 2025 | 01:41 AM
Pistnbroke's Avatar
Nothing under my rear seats except a gallon of water
Old Aug 26, 2025 | 05:20 AM
cat_as_trophy's Avatar
On an unrelated observation, but not to distract from the core of your thread, Wafoo . . .
Drool . . . I do love your contrasting double stitched leather
Old Aug 26, 2025 | 06:17 AM
Wafoo's Avatar
Its not to shabby inside....😀
Old Aug 26, 2025 | 08:35 AM
motorcarman's Avatar
Info about ARTS.
Old Aug 26, 2025 | 09:49 AM
I too wondered why a speaker on only one side until someone corrected me.
silversurfer1221
25
Nov 17, 2025 06:18 PM
pcolapacker
Jan 3, 2025 04:11 PM
adenshillito
Nov 26, 2023 07:42 PM
scottatl
Oct 10, 2022 08:53 AM
Borbor
Aug 22, 2022 02:03 PM
