Who used common battery instead off long "Jag" battery?
Old Oct 11, 2018 | 08:29 PM
car5car's Avatar
Default Who used common battery instead of long "Jag" battery?
I remember buying some "short" battery from junk yard for $20, it worked fine.
Old Oct 11, 2018 | 08:38 PM
You pays your money and you takes your chance.
Old Oct 12, 2018 | 03:36 AM
baxtor's Avatar
If you have thoughts of going "cheap" on the battery front, these cars are NOT where you want to be doing it.
Old Oct 12, 2018 | 06:13 AM
Jon89's Avatar
So many electrical problems (real as well as spurious) are attributed to failing batteries in these cars that it is simply not worth the monetary savings to scrimp on lousy batteries. Put a decent battery in the car, take care of it, and your overall ownership experience will be so much better....
Old Oct 12, 2018 | 08:49 AM
RJ237's Avatar
My 97 had a basic battery when I bought it and I ran it hat way for several months. As long as you use a maintainer to keep it charged it will be fine. But I don't think the difference in cost is that significant.
Old Oct 12, 2018 | 09:32 AM
jimmiejag's Avatar
Ditto the comments above. I recommend an Absorbed Glass Mat (AGM) new battery and a C-TEK battery tender to keep it up to speed. (I have one in my '99 XK8 and it has kept my electrical system free of "bugs.")
Don't go cheap when it comes to the electrical system on our cars.
Old Oct 12, 2018 | 10:36 AM
larueb's Avatar
When I purchased my '99 years ago it had a Walmart battery that had bushings on the hold down rods as it was small in length and height. It lasted for awhile but I put the correct battery in when it failed. Why try and save a few dollars on an incorrect battery when it is so vital to the car? Save somewhere else.
Old Oct 12, 2018 | 06:23 PM
car5car's Avatar
I have a battery tester, paid $50 20 years ago. I can check any battery (except cellphone battery ), no problem. You can go Autozone or Advanceauto, they can check battery w/o removing it.
Old Oct 13, 2018 | 08:25 AM
zray's Avatar
You can't go wrong with the NAPA Legend Premium AGM battery. Right size, good price, good warranty, and working very well for me.
As 100% of responders have pointed out, you can go wrong by trying to cheap out on the battery with these cars. The electrical system does NOT tolerate drops voltage.
https://www.napaonline.com/en/p/NBP9849
Z
Old Oct 13, 2018 | 09:15 AM
car5car's Avatar
More you know less you pay...
aholbro1
Oct 5, 2017 12:25 AM
sonicd0012
Nov 20, 2015 11:36 AM
michigan0713
May 25, 2015 02:11 PM
lizzardo
May 9, 2015 07:33 AM
cujet
Dec 26, 2013 12:36 PM
