Wider tires on stock rims?
Old Apr 18, 2022 | 07:45 PM
giandanielxk8's Avatar
Default Wider tires on stock rims?
The time has come for me to replace my rear tires, although, due to the tires I currently have on the car being out of stock everywhere, I could end up replacing the entire set with Firestone Firehawk Indy 500s instead of getting the same tires I have now for just the rears. Mind you, my front tires are still good so financially it doesn't make much sense. Here's where I have to wonder why Jaguar staggered the tires by only 10 mm? My current rear tires look ever so slightly stretched. I was wondering, instead of running 255/45/R18s in the rear, is it safe to switch to 265/45/R18s? It would make the rear tires look less stretched on the rim, and might improve traction?
Has anyone tried this?
The current setup is:
  • Front: 245/45/R18
  • Rear: 255/45/R18
Proposed setup would be:
  • Front: 245/45/R18
  • Rear: 265/45/R18
Old Apr 18, 2022 | 09:00 PM
baxtor's Avatar
  • Front: 245/45/R18
  • Rear: 255/45/R18
  • Front: 245/45/R18
  • Rear: 265/45/R18
The 20 inch wheels run 285's at the rear so your proposed width should not be a problem as far as clearance is concerned.
Suitable offset still needs to be used with whichever wheel/tyre combo you settle on.
Old Apr 18, 2022 | 09:10 PM
motorcarman's Avatar
I bought a 2000 XKR from another forum member and it came with 255/40 - 18 front, 275/40 - 18 rear
They fit in the wheelwells.
Old Apr 18, 2022 | 10:52 PM
zray's Avatar
did you like the way it looked ?
Z
Old Apr 19, 2022 | 05:16 AM
Stumpy's Avatar
Here is the comparison between the 255 and 265
Old Apr 19, 2022 | 08:51 AM
Z
I guess he did as he also put H&R wheel spacers but the front tires rubbed the fenders at times.
I removed the spacers but the tires look fine in the wells.
Old Apr 20, 2022 | 08:34 PM
professor2's Avatar
Default web site
Hey Stumpy,
Pretty cool info. Did you get that from a web site? Share the link?
Old Apr 20, 2022 | 08:51 PM
zray's Avatar
These have been useful for me:
tire size calculator
Tire size calculator
RPM calculator
Interactive RPM Range Computator Program
Z
Old Apr 20, 2022 | 09:49 PM
This is way more info than I expected. Unfortunately Costco doesn’t have a tire in that size without them being the ultra pricey Michelin Pilot Sport tires that are out of my budget.
Old Apr 21, 2022 | 05:19 AM
Stumpy's Avatar
Originally Posted by professor2
Hey Stumpy,
Yes. The site I used was: https://tiresize.com/tyre-size-calculator/
Old Apr 22, 2022 | 12:41 AM
Timeisrelative's Avatar
I too use tire size calculator quite frequently. One thing to remember, more for the original poster than anything, just adding to or taking away from the width number actually changes the height of the tire as well. Thats where the calculator comes in very handy.
Chap1958
Aug 14, 2020 06:16 PM
Cincy XE-RS
XE ( X760 )
Apr 25, 2019 11:34 PM
HavocX10
Apr 15, 2017 04:14 PM
JagYour
Feb 11, 2014 06:04 PM
