Wind noise at speed.
Old Feb 23, 2011 | 02:13 PM
Boztron's Avatar
Default Wind noise at speed.
I am experiencing a problem with wind. It seems that at speeds above 40 MPH there is a lot of wind noise coming from the drivers side. Not sure whether it is coming from the door seal or windscreen seal. Anybody have any idea how to stop this annoying sound.
2000XKR
1990 XJ40
Old Feb 23, 2011 | 03:00 PM
alfred's Avatar
Some mechanics have a stethescope that works like a directional sound reciever. This way they can isolate where the noise is originating from. After that your may need to figure out is the seal is fixable or needs replacing. Or... turn up the radio! My wife's Subaru was really bad for wind noise, I added a bit of foam rubber near the rear view mirror support and it solved the problem. Just took a few months to figure it out. A strip of paper held in the area might work as well to find the leak. If the paper stays tight it is not a leak area, if the paper can be slid out then you have a gap.
Old Feb 23, 2011 | 04:56 PM
Dennis07's Avatar
2000XKR
1990 XJ40
Suggestion: take a look at the fit between the door window and the rear window. Gap there? If so, try tugging on the rear window, pulling it forward. You can pick up maybe 1/4" that way.
Good luck.
Old Feb 23, 2011 | 09:13 PM
Glenn Barickman's Avatar
You can also try a piece of small rubber hose. Hold one end up to your ear and move the other end to locate the wind noise
Old Feb 23, 2011 | 09:42 PM
Reverend Sam's Avatar
The gap between the rear window and the front window is adjustable. Right now mine is intentionally mis-adjusted because my door-open microswitch is bad. As soon as I fix it I'm going to adjust the window. It's pretty easy, but you have to take off the door panel.
Old Feb 23, 2011 | 09:53 PM
GordoCatCar's Avatar
Insert a dollar bill between the door seals, window seals, etc., and run it around the openings in order to locate the gap(s).
Old Feb 24, 2011 | 02:44 AM
RayG's Avatar
I have the same on my 2005 coupe and it is the vertical rubber (plastic?) seal between the triangular "fill-in" behind the door mirror and front edge of the window. The seal does not remain fully in place at the top - causing the wind noise - but usually returns to its proper position if the window is opened and closed a time or two.
Old Feb 24, 2011 | 12:35 PM
alfred's Avatar
"Insert a dollar bill between the door seals, window seals, etc., and run it around the openings in order to locate the gap(s). "
Hey its a Jag, use a $20 bill and do it while you are driving... if the bill flys away, you found your leak!
Old Feb 26, 2011 | 07:46 PM
Beav's Avatar
Roll the windows up, turn the blower on high, close the doors and trace the outlines of windows and doors with a lit cigarette or candle - you'll soon see any leaks.
Old Feb 26, 2011 | 08:11 PM
I just adjusted my window to get rid of some wind noise. I made a video which is rendering right now. When it's done I'll upload it to youtube and post a link.
Old Feb 27, 2011 | 09:58 AM
I started a new thread on adjusting the windows. Here's the link: https://www.jaguarforums.com/forum/s...d=1#post312220
Old Feb 27, 2011 | 10:12 AM
PaulB's Avatar
We don't have dollar bills in Canada
Old Feb 27, 2011 | 11:31 AM
Use a loonie or a toonie.
I know, they won't work for that. I just wanted to say loonie and toonie. I think I still have a handful of toonies. Unfortunately I can't sneak them in when I paying for stuff like I can with Canadian quarters.
Old Mar 3, 2011 | 09:31 AM
Mark104's Avatar
I have wind noise also...Maybe I should put my top back up!
Old Mar 4, 2011 | 09:13 AM
PaulB's Avatar
Joachim1167
Nov 7, 2020 09:18 PM
JimC64
31
May 30, 2016 03:04 PM
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 06:43 PM
ChrisJay
Sep 27, 2015 09:08 AM
