wood trim question
Old Mar 4, 2011 | 09:32 PM
reko19's Avatar
Default wood trim question
I am planning to replace one of the trim panels since the one I have is cracked. How do I go about making sure the color matches if I buy it on line sight unseen? Thanks.
Old Mar 4, 2011 | 09:41 PM
WhiteXKR's Avatar
The veneers across the dashboard panels have matching grain and color (literally off the same log). so you cannot get a perfect match without replacing all of the panels.
If you are not that picky, maybe you can convince a seller to send you one on approval, and see if it is close enough for you. The color in photos is too variable to really judge.
Old Mar 4, 2011 | 09:45 PM
reko19's Avatar
thanks, I was hoping that same year models were similar in color. you are right photo is not a good way either...
Old Mar 4, 2011 | 09:55 PM
WhiteXKR's Avatar
Maybe your best bet is to see how much it would cost for someone like http://www.britishautowood.com/ to repair your cracked one.
Old Mar 4, 2011 | 10:43 PM
Frank M's Avatar
If your vehicle is something you would like to keep factory, send the panel out to be repaired.
Old Mar 8, 2011 | 06:59 AM
jnporcello's Avatar
My passenger side dash wood panel had a large crack, which was in the finish and not the wood itself, which is most likely even if it looks like its in the wood. I sent it to www.maderaconcepts.com for complete refinish. They sent it back about a week later good as new. Pretty sure the price was $150 to $200 range.
Old Mar 8, 2011 | 10:11 AM
reko19's Avatar
This sounds very reasonable, I'll get in touch with them. How hard it to remove it. There are two straps attached to the airbag cage, do I have to take the whole assembly out? Thank you.
Old Mar 8, 2011 | 11:26 AM
Frog's Avatar
I am planning to replace just the centre part of the dash as part of my 'downgrade' from the OE satnav to the 3 instruments. I have sent a photo of my dash to a handful of Jaguar breakers in the UK and asked them to look out for as close a match as possible. I have been advised the cost will be about £60.
Old Mar 8, 2011 | 12:56 PM
xenophobe's Avatar
I really want to get my whole set + door cappings done by them. They have some really pretty burl on that site.
Old Mar 8, 2011 | 02:34 PM
XKRacer's Avatar
Get in touch with Myrtle Prod they will match your wood pretty good, would be vey hard just to try and match from a breaker, a bit hit n miss.
Of course you can cheat and get a spare set and go for a piano black finish
Old Mar 8, 2011 | 03:30 PM
Reverend Sam's Avatar
...or carbon fiber.
Old Mar 8, 2011 | 05:27 PM
K.Westra's Avatar
Originally Posted by Reverend Sam
...or carbon fiber.
Boooo Carbon Fiber! Piano black is nice. Burled Walnut is nicer
Old Mar 8, 2011 | 08:55 PM
Gus's Avatar
Gus
Carbon WHAT? Fiber!! Who needs fiber?
Old Mar 9, 2011 | 12:25 AM
Frog's Avatar
Thanks for the link, XKRacer.
As for CF, I agree: it's one of those things that sounds cool until you actually see it... I'll be sticking with Jaguar elm
Old Mar 9, 2011 | 06:21 AM
jnporcello's Avatar
The passenger side involves a little work, but ultimately not too bad. Disconnect battery and let sit for 1/2 hour or hour to let capicitors drain, etc so that the airbag isn't energized.
Remove glove compartment - I think there are 4 screws/bolts. Then you do need to remove the airbag module because there is a strap that connects it to the wood panel so it doesn't blow off in a passenger's face if the airbag deploys. From what I remember, there are 4 bolts holding that onto a bracket. The wood veneer pries off very easily because it has a metal backing, so its really not very delicate, its a pretty tough piece. Then remove the airbag module and veneer piece and there's a pin that holds the nylon strap to the veneer, which you can pound out.
Hope that helps. Between that and the pics in JTIS, it should be doable. I was a little nervous to get into it, but it wasn't too bad. Go for it.
Old Mar 9, 2011 | 07:43 AM
reko19's Avatar
Being new to all this I did not even think about checking JTIS, pretty detailed instructions there. Thanks for pointing me in the right direction.
Old Mar 12, 2011 | 12:32 PM
reko19's Avatar
was able to get it out today, JTIS gives pretty good instructions. will be sending it to heritage woodwork for refinish, will report once I get it back
regards
Old Sep 1, 2013 | 06:58 PM
rogers1511's Avatar
What is JTIS where can I find it?
Old Sep 1, 2013 | 08:50 PM
Bad Cattitude's Avatar
https://www.jaguarforums.com/forum/x...archive-66011/
way2far
Aug 31, 2022 09:26 AM
Rivguy
Dec 4, 2020 07:55 AM
Forcedair1
Feb 19, 2020 01:51 PM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
al_roethlisberger
Sep 7, 2015 10:53 PM
