Wow us with your XK8/R photos
Old Oct 2, 2019 | 02:17 PM
  #2261
vg99999's Avatar
This is XKR 2.5\" setup
This one is to compensate technical stuff above)
Originally Posted by SamtheSham
What mufflers did you use? Did you eliminate either of the muffler/resonator sets? Any modifications needed for the O2 sensors?
I am considering doing some muffler modes for better sound/performance on my XK8. Don't expect a lot of increase in hp, but would like a little better noise?? A little of the Old Hot Rodder still left.
I have done 2 different setups:
XK8: 2.25" 200cpsi Magnaflow CATS, 2.25" X-pipe, 2.25" red Magnaflow resonators, rear Magnaflow XL mufflers (empty, with turbo effect, as they say), 4" double wall tips. Result - really beautiful sound without drone, sometimes explosions, and when you go to manual mode sounds much better, especially while shifting down. Despite relatively inexpensive parts, altogether with labor costs about 2ooo EUR. From my opinion, it worth amount and efforts. From the other side, if to use only Adamesh overaxle pipes from ebay, it should sound beautiful as well (even if to delete only one pair of silencers before axle and leave everything else as it is). Or, delete this mentioned above pair of silencers, by replacing them with Adamesh pipes (about £180 + labor), and delete rear stock silencers, replacing them with another Adamesh pipes (another £180+), but add pair of Magnaflow resonators (approx £120 for pair), to avoid drone on high rpms. It must sound pure and powerful too. If I'm right, it will cost 3 times less with almost same effect. Stock central part is resonator +X-pipe, and when you delete everything else beyond it and add just resonator, it will be almost the same logic as racing version of Aston DB4 - it has just pair of approx. 40" long resonators, not sure about cats. Anyway, here is the image of new cats with stock O2 sensors, and everything else.
XKR: all Magnaflow 2.5": 200cpsi cats, X-pipe, short central resonator behind it, underaxle pipes leading to large resonators (I think it would be better to use smaller round ones).
Old Oct 2, 2019 | 04:33 PM
  #2262
SamtheSham's Avatar
That's the info I was looking for. I believe if you remove anything downstream from the O2 sensors, the ECU will read o.k. Hopefully some of the techs smarter than me can confirm/correct this. Looks like what you did worked well.
I am not trying for a full-on Hot Rod sound, just a little more growl when I accelerate occasionally. The 'Sport' mode on my F-Type does a nice job of this when I want it. Not so with the XK.
Old Oct 3, 2019 | 02:25 AM
  #2263
ericjansen's Avatar
Simple, unmodified, pure ... just as Jaguar designed it, just as what I wanted.
Old Oct 4, 2019 | 01:17 PM
  #2264
nnyvr's Avatar
Old Oct 4, 2019 | 02:59 PM
  #2265
Mr Bentwrench's Avatar
I think this will be my submission for our Club's 2020 Calendar contest. Only allowed one entry per car and so far this one of my three test shots is polling the best. (still uncropped or run through the digital darkroom)
Old Oct 7, 2019 | 10:10 AM
  #2266
Rosettaquarrier's Avatar
Here's a picture of mine from Saturday - Wolf Creek Pass, Utah.
Old Oct 14, 2019 | 09:24 PM
  #2267
Ledmi's Avatar
Default My 2006 XK8 Victory Édition
This is my week-end Jag. Week days I use an 2017 XF-S but I can’t wait for week-end for the real fun of driving around in back country.
Old Oct 14, 2019 | 10:48 PM
  #2268
Iscsam's Avatar
Default 1998 XK8
145,900 miles and still running strong. Original paint and nikasil engine.
Just hit 175,000 miles.
1998 xk8
Old Oct 15, 2019 | 07:05 AM
  #2269
SamtheSham's Avatar
Default Great Shots
Beautiful Car, beautiful Photos.
Old Oct 22, 2019 | 09:29 PM
  #2270
Droptopcat's Avatar
Back from the shop. Looking pretty
Old Oct 24, 2019 | 04:24 PM
  #2271
jimmiejag's Avatar
ISCAM,
I am rather partial to that color combination: it's the same as my '99.
Old Oct 24, 2019 | 06:17 PM
  #2272
bcprice36's Avatar
Smile Eric, You've reallly done a great Job on the Coupe!!
[QUOTE=ericjansen;2134256]Simple, unmodified, pure ... just as Jaguar designed it, just as what I wanted.
Old Nov 11, 2019 | 09:40 PM
  #2273
rothwell's Avatar
On November 8th a few of us in the Tampa Bay area met up for breakfast again - and remembered this time to take pics.
cars L to R are owned by Muncie6spd, srpope80, rothwell
We plan to do it again next month. PM me if you are interested in joining us.
Old Nov 16, 2019 | 07:49 PM
  #2274
Ronald Vennell's Avatar
I finally got a decent photo of my '97. This is at Kent Falls State Park in Kent, Connecticut.
Old Nov 16, 2019 | 07:53 PM
  #2275
I picked up this '99 2 weeks ago. My intentions are to do an LS conversion on it. It's a good solid car but cosmetically needs some TLC. This will be a multi-year retirement project.
Old Nov 17, 2019 | 10:52 AM
  #2276
michaelh's Avatar
Is the powertrain dud in the '99 or just a project that you want to do?
Carnival red always looks great, IMO.
Old Nov 17, 2019 | 11:27 AM
  #2277
The powertrain seems fine. It's had the timing chain work done. I flew up to CT and drove it 6 hours home and it ran great.
It's going to be a multi-year retirement project. A full "frame off" resto-mod.
Old Nov 17, 2019 | 11:56 AM
  #2278
bcprice36's Avatar
Smile A better Idea!
+Ronnie,
Sorry, but if you wanted a Corvette, why didn't you Buy One and spend your money and time on it! Now that you have what appears to be another X-100, spend your time and "Money" rebuilding it to be a Jaguar....You can get all kinds of parts, such as Engines, Trannys and just about everything for the XK from several different Wrecking Yards and completely change the drive-train on this XK8. Put a 4.2 S/C Engine in it.....Anything to keep it a Jaguar....That will keep you busy.....
The Photo of the Convertible looks great...You've got a deal looking Car to start your project....!
Billy Clyde in Houston
Old Nov 17, 2019 | 12:05 PM
  #2279
bcprice36's Avatar
+Ronnie,
Old Nov 17, 2019 | 03:51 PM
  #2280
Originally Posted by bcprice36
+Ronnie,
Corvettes are cool but they just aren't my cup of tea. A 400+HP, 400+ft/lb X-100 on the other hand......
