Wrong MAF?
Old Jan 12, 2023 | 04:09 PM
Dargam's Avatar
Default Wrong MAF?
Hello everyone,
Just purchased a rough XKR 2003 4.2. Today I fixed a coolant leak. The car runs very rich and looses power sometimes when I push the pedal. I will receive my OBD reader tomorrow to pull codes. In the mean time I removed the MAF sensor to clean it, and realised the number might be incorrect. Cant find much info.
Its a Denso part number mb197400-3021 and also has 1X43-12B579-AB.
Please advise.
Thank you
Old Jan 12, 2023 | 04:41 PM
Dargam's Avatar
Ok doing further research I think this would fit a 4.2 XK8 and not the XKR. Maybe this is whats causing the car to run very badly. Seriously I dont understand why people change wrong part numbers.
Old Jan 13, 2023 | 03:40 AM
Pistnbroke's Avatar
Seems to be 197400-2090 but get confirmation before you buy.
The fuel trims should be out if its wrong .
Old Jan 13, 2023 | 05:32 AM
JagV8's Avatar
Best not to assume... wait for the OBD codes, including P1111/P1000 (if the latter, which OBD monitors haven't set), and fuel trims.
Old Jan 22, 2023 | 01:43 PM
britannia's Avatar
Denso 197-6030 works fine from Amazon $58. Made in Vietnam comes in Denso box!
Cheers Adrian
Old Jan 22, 2023 | 03:08 PM
Dargam's Avatar
I got Denso 1976040 as recommended elsewhere in the forum, now the car runs much better. No more rich fuel smell. I changed the coils and spark plugs as well, and guess what the ones on the car are wrong parts as well.
As its new to me, I will have to solve other issues with it. Next is to look at why I have all O2 sensor codes but no check engine light even after reset. I am using Foxwell NT510 elite with Jaguar software.
Thanks for everyones support. This forum is amazing.
Old Jan 23, 2023 | 10:21 AM
britannia's Avatar
Dargam, glad your 197 6040 works ok; USA Denso distributor ,in Calif. NOT allowed to give out part nos because of agreement with JAGUAR!! As an ex Brit I'm disgusted at Jaguar (as usual) so we now know that both 6030 & 6040 WORK! AMAZON states ONLY 6030 WORKS!
Cheers, Adrian
Old Jan 24, 2023 | 08:27 AM
dfbender's Avatar
Cheers, Adrian
I just checked and Amazon now says the 6030 does not work for ‘02 XKR. Glad to know these will work.
Old Jan 24, 2023 | 02:03 PM
zray's Avatar
yes, the 4.0 XKR cars will start and run with the 4.0 XK8 MAF sensor installed. But the calibration is not the same, and you won’t get all the performance the 4.0 XKR is capable of giving.
The only cars that use the 4.0 XKR sensor are the 4.0 engine XKR and XJR’s. That’s why they are so expensive. I got one from a Jaguar dealer for a modest discount. None of the aftermarket MAF sensors worked worth a damn. And neither did the sensor for the 4.0 XK8 even though it was a Denso.
I think sensor for the XKR ‘ XK8 4.2 models is the same, and is used on other makes as well. It’s reasonably priced. But the 4.0 XKR sensor is costly if the right one is sourced.
Z
Old Jan 24, 2023 | 04:52 PM
Dargam's Avatar
I honestly found the info that 1976040 will fit in this great forum. Then checked all Denso DMA0114 part numbers for my 2003 XKR 4.2 in below link.
https://www.denso-am.eu/catalog/pv/16989/part/DMA-0114
then I checked Autohauzas which states the 1976040 works.
https://www.autohausaz.com/pn/1976040
Then went to Amazon and got it although it says does not fit.
Again thanks for everyones support.
Old Jan 24, 2023 | 05:23 PM
zray's Avatar
Yeah, both of the 4.2 models use a common MAF that is used on other cars as well.
It’s the 4.0 XKR’s and XJR’s that use the pricey MAF.
funny how the 4.0’s and 4.2’s both have pricey parts (fuel pumps and MAF’s for example) that are reasonably priced on the other model.
The 4.0 fuel pumps are commonplaces and priced well, but the 4.2 uses an expensive pump. The reverse is the case for the 4.0 XKR MAF’s.
Z
Old Dec 3, 2024 | 02:15 PM
NorXKR's Avatar
From my XK8 / XKR Parts List:
97-98 XK8 LJA1620AE
99-02 XK8 LJA1620CB
99-02 XKR LJA1620BB
03-05 XK8 C2S002670
03-05 XKR C2C007636
Old Dec 4, 2024 | 03:27 AM
dibbit's Avatar
Z
Old thread, but it's lucky our MAF sensors, along with many other expensive bits on the car, last for 20+ years.
Maraud
Jan 22, 2023 02:44 PM
mpasiuk
Dec 5, 2022 06:25 AM
Anglicomarine0326
Aug 29, 2021 05:59 AM
randyb
Apr 7, 2012 02:09 PM
blast20
Mar 26, 2012 12:47 PM
