Help!!
When i turn on the cruise control swith, as i am driving, then i push the set button, the Failsafe Engine mode turns on. One guy said to replace an electronic box near the break pedal. I replaced it but no luck. So my cruise control doesnot work.. any Ideas???
Gus
close
- Join DateJul 2008
- LocationBerlin Md.
Liked:2,234 Times in 1,714 Posts
You should check the brake switch. Is that what you replaced?
Gus
close
- Join DateJul 2008
Can you pull the OBD codes and post them?
When I turn the car off it resets itself, so I Have to re engaged the cruise control to get the error message. I have a pending code of P1111. The last 6 digits of my VIN is 027727.
Gus
close
- Join DateJul 2008
Good to know but do you know what hose was clogged?
