XK8 aerial is dead
Old Oct 3, 2014 | 06:44 AM
looops's Avatar
Default XK8 aerial is dead
Hi all.
My aerial goes neither up or down; no motor action at all. I've had it apart and put 12v on the connector and the motor spins fairly fast then slow then fairly fast seemingly forever. I've measured 12v coming out of the radio side of the connector so assume all is good there.
Does anyone know if there should be 12v pulse from the head unit at switch on or off?
If the aerial does need replacing anyone know an affordable (UK) replacement?
Thanks.
Paul.
Old Oct 3, 2014 | 08:38 AM
larueb's Avatar
I replaced the one on my '99 with one from a junk yard or breaker as they say. The new OEM is grossly over priced. I replaced it 2 years ago and it still works great. It is a little fiddly to install but no big deal.
Old Oct 3, 2014 | 10:34 AM
graham11's Avatar
Default aerial
hi mate,£32 new with all fittings ebay free post.
Old Oct 3, 2014 | 11:39 AM
looops's Avatar
Jag XK8 specific with the right connector or generic thing needing wiring surgery?
Old Oct 4, 2014 | 03:29 PM
Stamford's Avatar
A common antenna problem is the teeth on the flexible plastic strip that raises and lowers it can get worn away. If so, you may be able to get away with just replacing the mast. I had my "old" XJ-S for about 20 minutes before I broke the mast. Being a 6.0-liter, it had a spoiler on the deck lid. At the time, I didn't know you had to wait a couple of seconds after popping the trunk to allow the mast to go down. I ignorantly threw the truck open and the spoiler bent the mast but good. Found a replacement mast on ebay. Ditto on the overpricing of the OEM. Generic substitutes are available on ebay, also.
Old Oct 5, 2014 | 03:14 PM
looops's Avatar
Thanks for the reply, I've had it apart and the motor doesn't spin at all.
Old Oct 6, 2014 | 08:21 PM
Vman1's Avatar
Default aerial issues
Hey, a few years ago the same happened to me. I cleaned the fine gap between the windings in the rotor. They were filled with copper dust and grime. I used a razor blade and contact cleaner. Reassembled, and as I said, it's been a few years!
Old Oct 6, 2014 | 11:21 PM
StifeJa's Avatar
Default Dead antenna
I use a small piece of folded 2000 grit sand paper to clean relay contacts and connectors. search on line for XK8 antenna switch, there is a video of putting in a switch that shows the wire location at the harness connector in the ceter console. This should have 12V when ever the head is turned on.
Steve J
Old Oct 7, 2014 | 05:59 AM
JonWat's Avatar
Are you sure it's got power?
There is a
Old Oct 7, 2014 | 06:15 AM
Dennis07's Avatar
Loops,
In 1st post, you said motor spins sporadically. Now it doesn't spin at all?
I'm confused (nothing new).
Old Oct 7, 2014 | 06:59 AM
jamdmyers's Avatar
Almost every electric motor failure I've seen is due to carbon brushes either worn out or cupped which then cause them to stick in the winding slots. I've fixed oh so many by this repair, if the brushes are still in good shape and springs allow for contact just sand them flat again. That is if you can disassemble the motor itself, I've ran across riveted cases but those too can be drilled and fixed.
Old Oct 7, 2014 | 09:32 AM
looops's Avatar
Thanks for the posts folks. I've now cleaned the rotor contacts with contact spray and a plastic blade and it's spinning well now; but only when powered by a test battery.
Can someone confirm for me: At the connector there should be Ignition 12v +, GND and switched 12v+ when the radio is on and no switched 12v when it's off? If so is it a timed 12v+ switched?
Old Oct 8, 2014 | 06:53 AM
StifeJa's Avatar
Default Power at the antenna motor
Correct : At the connector there should be Ignition 12v +, GND and switched 12v+ when the radio is on.
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
oldjaglover
Dec 25, 2024 04:33 PM
Presence
Mar 13, 2016 02:21 PM
oldjaglover
Sep 29, 2015 03:27 PM
