XK8 engine noise, what is that?
Old Aug 30, 2013 | 06:00 AM
AP3's Avatar
AP3
Default XK8 engine noise, what is that?
XK8 engine noise, what is that? - YouTube
I can't figure out this noise. This is with or without serp belts. The belt tensioners are fine on the top side. The chains were tight and the cams are in alignment. No engine light, I have not checked the codes yet. Help please.
http://www.youtube.com/watch?v=xGaeK...ature=youtu.be
Old Aug 30, 2013 | 06:57 AM
philhef's Avatar
Not a mechanic here but I do notice that the sound seems to perfectly be in sinc with the white marks on the belt. Just an observation so possibly a good place to start? And it sounds like a squeaking. Something rubbing. I tend to notice any slight squeak either in or outside my car. You sure every bolt is tight? I had a bolt on my fan housing that was loose and when I tightened it, my squeek went away. Not the same sound but similar.
Did you check water pump? There's another youtube video with a similar sound and they all suggest water pump. "Engine Noise Jaguar"
Old Aug 30, 2013 | 08:24 AM
motorcarman's Avatar
Some of these might help
bob gauff
File Type: pdf
File Type: pdf
Old Aug 30, 2013 | 08:46 AM
Gus's Avatar
Gus
Look down to the alternator and see if the belt is jumping.
Old Aug 30, 2013 | 05:41 PM
AP3's Avatar
AP3
The sound is the same without the belt on too
Old Aug 30, 2013 | 08:25 PM
Gus's Avatar
Gus
It sounds like a valve problem. Were the tensioners just recently replaced? It is a rhythm and it sounds consistent. Do you have a stethoscope to narrow down the location?
Old Sep 3, 2013 | 05:34 PM
AP3's Avatar
AP3
Bought stethoscope today. Definitely noise from the lower tension-er front chain area. If I have bent valves, how hard is that to do. I have very little mechanical experience. Doing the upper tension-ers was not difficult, but is 99% of my mechanical exp.
Old Sep 3, 2013 | 06:23 PM
Beav's Avatar
Bent valves would cause the engine to misfire due to reduced/no compression in a cylinder(s) - that doesn't seem apparent here. Ancillary devices (water pump, alternator, etc.) won't make noise if the belts are off guys. It doesn't appear that the dampener is out of whack and rubbing the cover. Hearing the noise through the stethoscope coming from the cover means you'll be taking it off...
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
PMKimpton
Aug 3, 2019 08:22 PM
cissdm
May 3, 2016 06:02 AM
innzane
Sep 2, 2015 10:08 AM
