XK8 rear subwoofers
Old May 11, 2019 | 10:54 AM
Jimf's Avatar
Default XK8 rear subwoofers
All the recommended rear replacement subwoofers for 1998 XK8 with Harmon karden system are discontinued. There are no recommendations for ones that will fit and sound decent past 2013. Don’t need thumping, just decent price and sound. Any recommendations? My factory ones are blown for second time. Replacing them myself this time.
Old May 11, 2019 | 12:04 PM
DavidYau's Avatar
Default I used Kickers ordered from Crutchfield
Hi,
i used Kickers CompRT subwoofers, ordered from crutchfields website.
Check out the previous thread.
https://www.jaguarforums.com/forum/x...eakers-214035/
I would suggest you check your mount’s hole diameter exactly before ordering.
Old May 11, 2019 | 02:33 PM
Welcome to the forums Jimf,
Old May 12, 2019 | 05:40 PM
ccfulton's Avatar
You don't specify coupe or convertible, which will lead you down different paths but one thing to note about the coupe is that is rather an odd size. It has been a number of years since I replaced mine, but if I recall the OEM size if 8+some odd. I ended up mounting a shallow depth 8" and had to make an adapter plate for the package tray.
Old May 12, 2019 | 06:02 PM
Jimf's Avatar
Default Subwoofers
It is a convertible. This the two rear panel subs.
Still looking for replacement models that will fit without modifications except for the ring. I don’t want to take everything apart just to figure the dimensions.
Apparently this is common to replace. Someone can hopefully help with a make and model sub that will fit and work.
Old May 12, 2019 | 09:52 PM
Ltd's Avatar
Ltd
Default Subwoofers
Jim,
I used Pyramid PW677x6” 300 watt 4 ohm. Fit right in. I do have the premium sound. I also replaced the itty bitty tweeter while in there.
ltd
Old May 13, 2019 | 06:27 AM
Jimf's Avatar
Default Rear subwoofers
Thanks for the info.
Old May 13, 2019 | 02:31 PM
hirev's Avatar
i believe i used infinity speakers, took old ones out and went to best buys with them, matched the size, including depth with what they had and bought them for about $100 two way speakers i think it was years ago, but the work took hours and i had to solder the wires as there is little room to work with the shot wires provided. works perfectly.
Old May 20, 2019 | 08:51 AM
marvin.d.miller's Avatar
If you want to retain the stock speakers, google "Recone Speakers"
Old May 20, 2019 | 04:27 PM
Jimf's Avatar
Default Rear subs
Thanks, I’m thinking of doing that to even keep them as a backup set.
RobXK8
Oct 30, 2017 07:08 PM
GordoCatCar
Oct 21, 2015 04:29 PM
BadDog42
May 17, 2015 08:13 PM
phd12volt
71
Feb 2, 2014 09:57 PM
flblue
Jan 16, 2014 10:22 PM
