XK8/XKR - Non-OEM interchangable Parts Thread
Old 04-05-2014, 09:00 AM
Received 4,182 Likes on 3,645 Posts
Default XK8/XKR - Non-OEM interchangable Parts Thread
Thanks to zjdmm1 for the recommendation - this sticky is to provide an easily searched location for alternative, non-OEM part fixes for our XK8/R's. I will leave this open so others can add.
REAR VIEW Mirror FIX
HELP! I need a new rear view mirror clip for my XKR!
Does anybody know where I can get a replacement clip? I haven't been able to find a listing or part number on any of the dealer sites.
Thanks in advance!
The same mirror is fitted to an Acura tl - check if a clip is listed separately by an Acura dealer. Check my earlier post about the Acura part number for the mirror to help the search.
Thank you for your advice! My local Acura dealer came through for me. They looked up a clip using the application of a 2007 Acura TL. They came up with part #76419-SZ3-J05. They had one in stock...It's a perfect match! They charged me $6.07, including sales tax. A bargain, considering I found a used clip for $50 on the web.
You're welcome! You could have bought the whole mirror for another $74 and even at that the Acura dealer is making money - the same mirror is over $300 from a Jag dealer - pretty good mark up in anybody's world
Aftermarket coils
I saw this site recommended here and I recently purchased a complete set of these for around $300 as opposed to over $600 for OEM.
1997 2003 Jaguar Vanden Plas XJ8 XJR XK8 XKR V8 Ignition Coil New | eBay
Alternate Tensioners
Ford PN 2W9Z6K254BA Right Secondary metal bodied Tensioner (1 required)
Ford PN 2W9Z6K254CA Left Secondary metal bodied Tensioner (1 required)
Ford PN W500301S300 Bolt (4 required - YOU MUST USE THESE NEW, SLIGHTLY SHORTER BOLTS)
Gaskets
4.0L S/C engine can use the fel-pro gasket set provided for the Lincoln LS: VS 50397
http://www.rockauto.com/catalog/x,ca...parttype,10710
The following 25 users liked this post by sklimii:
blue nose (08-22-2017), Bob OB (06-01-2014), brantman (01-23-2015), CorStevens (02-18-2019), crobii (07-28-2022), danand (06-21-2014), Don B (10-29-2019), eszpulecki1 (12-24-2021), ex-dutchman (07-14-2014), jaghopes (03-12-2017), JimC (02-21-2016), johns427 (09-22-2014), McMillan73 (04-29-2015), Mundo (11-01-2020), niceramaykina (10-10-2016), NS2000XKR (10-10-2015), OA5599 (10-05-2017), Orthodixie (04-19-2017), piper 888 (06-12-2019), poppop (09-18-2016), preuss2 (05-05-2014), Rogerj (10-17-2016), Sir Alex of Yotto (04-17-2016), Syb Drylst (07-12-2020), zjdmm1 (04-06-2014) and 20 others liked this post. (Show less...)
Top Answer
04-10-2014, 10:48 PM
zjdmm1's Avatar
zjdmm1
zjdmm1 is offline
OE Oil Filter
EAZ1354 OIL FILTER $28.57
Alternate Part
Motorcraft - Oil Filter
Part # FL2021 List Price $9.49 @ O'Reilly Auto Parts
OE Air Filter
NJA3558AA List Price $84.46
Alternate Part
WIX - Air Filter
Part # 42461 List Price $26.99 @ O'Reilly Auto Parts
I can't take credit for the info.. I found the information buried in several forum threads.. I'd give credit to the original posters but I've been reading so much of the forum lately that I can't remember exactly who originally posted or what threads it was in... as always... YMMV ... I'm giving both a try...
Update: 5/9/2014 - Both are currently fitted on my 02 XKR. The WIX Air filter is an exact fit. The Motorcraft Oil Filter (per motorcarman) is a direct fit for the 4.2 engines (the 4.0 stock one is longer but using the Motorcraft one won't cause any issues) The Motorcraft threads, seals, and works just fine for my 4.0 engine
Old 04-10-2014, 10:48 PM
zjdmm1's Avatar
OE Oil Filter
Alternate Part
OE Air Filter
Alternate Part
WIX - Air Filter
The following 29 users liked this post by zjdmm1:
5V1900 (09-06-2014), Abby's Guy (02-08-2021), blue nose (08-22-2017), Bob OB (04-20-2014), CorStevens (02-18-2019), crobii (07-28-2022), DarcySmith (05-10-2023), edstoll11 (09-08-2014), eszpulecki1 (12-24-2021), ex-dutchman (07-14-2014), Jag Pilot (08-17-2014), jaghopes (07-22-2016), JeffG94 (10-04-2015), MRomanik (06-08-2014), MrsToadsWildRide (09-19-2016), OA5599 (10-05-2017), obwoodie (12-12-2015), olddavidp (06-03-2023), Orthodixie (04-19-2017), phyllisita (12-27-2016), piju1945 (10-26-2015), piper 888 (09-04-2023), poppop (09-18-2016), preuss2 (05-05-2014), Rogerj (07-12-2016), Rudy Abbott (01-25-2021), Shelorr (12-23-2015), Superchargedxkr (01-28-2023), zray (12-04-2018) and 24 others liked this post. (Show less...)
Old 06-07-2014, 09:42 AM
larueb's Avatar
Default Serpentine belt
for '99 XK8 Dayco 5070915 exact fit
The following 10 users liked this post by larueb:
arttomlin (04-04-2015), bherr (06-20-2023), Jag Pilot (08-17-2014), mel98xk8 (06-08-2014), MRomanik (06-08-2014), olddavidp (06-03-2023), Orthodixie (04-19-2017), Rogerj (10-17-2016), Shelorr (12-23-2015), zjdmm1 (06-08-2014) and 5 others liked this post. (Show less...)
Old 06-29-2014, 05:14 PM
rustyxk8's Avatar
Here is another substitute for both left and right idlers:
Gates 36270, purchased at NAPA as NAPA part number NBH 36270.
It is metal and has inboard and outboard shoulders. I adjusted the width of the new serpentine belt to better fit the pulley. Here are pictures of the old pulley that failed and my nice ride.
Attached Thumbnails XK8/XKR - Non-OEM interchangable Parts Thread-xk8idler.jpg   XK8/XKR - Non-OEM interchangable Parts Thread-my99xk8.jpg
The following 12 users liked this post by rustyxk8:
akka (07-24-2014), arttomlin (04-04-2015), eszpulecki1 (12-24-2021), gyoungwolf (02-26-2015), Jag Pilot (08-17-2014), JohnG-47 (07-16-2020), justenough (06-02-2015), Rogerj (07-12-2016), Rudy Abbott (01-25-2021), Shelorr (12-23-2015), TedV (08-27-2020), zjdmm1 (07-07-2014) and 7 others liked this post. (Show less...)
Old 08-16-2014, 12:09 PM
macuser's Avatar
Thank You
Old 09-19-2014, 12:37 PM
scardini1's Avatar
Default '03 XKR XK8 Fuel Filter
This $10.00 filter (or it's equivalent) is available at most auto parts stores. Use the codes FF677 and/or G6340 for cross referencing. Just cut away the plastic clips and it's a perfect fit. Should be be good for at least '03, '04 and '05.
The catalogs will steer you toward the threaded end filter (also in the pic). I think they're for earlier cars than mine, but I don't have the specifics.
Attached Thumbnails XK8/XKR - Non-OEM interchangable Parts Thread-purchased-filters.jpg
The following 6 users liked this post by scardini1:
edstoll11 (10-03-2014), fourkegdave (01-21-2020), Jon89 (09-19-2014), Orthodixie (04-19-2017), Rogerj (07-12-2016), zjdmm1 (09-25-2014) and 1 others liked this post. (Show less...)
Old 09-24-2014, 12:11 PM
macuser's Avatar
Thank You
Old 10-01-2014, 07:02 PM
StifeJa's Avatar
Default U Joints - these from GNK are genuine
I got some GNK U22 Universal Joints and was suspicious as to if they are really GNK's. They say GMB and made in Japan. I took Photos and contacted GNK. Emailed the pics. THEY ARE REAL.
Regina
Customer Service, Rockford | GKN Land Systemser
Called me and emailed me back. She stated that they are engineered/outsourced from the GNK division in Germany. These meet GNK specs and are real.
Attached Thumbnails XK8/XKR - Non-OEM interchangable Parts Thread-img_gkn-label2.jpg   XK8/XKR - Non-OEM interchangable Parts Thread-img_gnk-upc4.jpg   XK8/XKR - Non-OEM interchangable Parts Thread-img_gnkasgmb.jpg   XK8/XKR - Non-OEM interchangable Parts Thread-img_endcap6.jpg   XK8/XKR - Non-OEM interchangable Parts Thread-img_gmb8.jpg
The following 8 users liked this post by StifeJa:
crobii (07-28-2022), GT'thusiast (03-01-2020), olddavidp (06-03-2023), Orthodixie (04-19-2017), Rogerj (07-12-2016), szhilian39 (12-31-2021), t.flockhart (01-30-2024), zjdmm1 (10-06-2014) and 3 others liked this post. (Show less...)
Old 10-05-2014, 09:53 AM
new addition
Originally Posted by stevepaa
Found gates pn 27041 as equivalent to Jaguar stuff at .39 per foot at O'Reilly
spray a little silicone on tubing to get it through springs and cut one end on diagonal to get through hole on pax washer arm
The following 3 users liked this post by sklimii:
Rudy Abbott (01-25-2021), szhilian39 (12-28-2021), zjdmm1 (10-06-2014)
Old 10-31-2014, 12:48 PM
K.Westra's Avatar
TPS Sensor Repair plug
(useful if your plug is damaged, or if you damage it performing TSB303-58, or if you don't want to do the full TSB to try to solve a P0121)
Designed Fitment: Toyota or Geo Prizm
Brand:Standard Motor Products
Manufacturer Part Number:RPCTH151
Interchange Part Number:213-446, 213930
Other Part Number:89452-33010, 94853125
Other Part Numbers:1985003011, 89452-06010, 89452-12050, 89452-22090
The following 2 users liked this post by K.Westra:
sklimii (10-31-2014), zjdmm1 (11-10-2014)
Old 10-31-2014, 01:58 PM
RDMinor's Avatar
Default Trunk lights diode & micro-switch
The inline connector from the trunk light plugs to their grounding lug is a one-way diode designed to keep the trunk lights from being energized by any electrical system feedback should the micro-switch fail.
The connector is marked 91 AG 10374 BA and is available through your local Ford dealer under part # E9RY-10374-A at a cost under $20.00.
The micro-switch is part# LNC6242AB and can be found on eBay and other sources used for $25-$35. Usually attached to some part of the latching mechanism which can be trashed if unneeded. It was used on both the XK8's and XJ's from 1997 - 2003 (at least & probably longer). It is mounted inside a small black case that is pretty fragile so I just used a small screwdriver (or pick) to release the four latches (one at each corner) and then removed the switch. Replaced with working switch and then re-latched.
You can test the switch without removing it by finding the wire connector (12"+/- from switch) and running a continuity check with a multi-meter with the trunk open. No tone means switch is defective as the switch is in the closed (or ON) position with the trunk lid raised.
Attached Thumbnails XK8/XKR - Non-OEM interchangable Parts Thread-2014-10-31-14-45-10.702.jpg   XK8/XKR - Non-OEM interchangable Parts Thread-2014-10-31-14-46-50.044.jpg
The following 7 users liked this post by RDMinor:
eszpulecki1 (12-24-2021), HalBrown (02-03-2021), Orthodixie (04-19-2017), Rogerj (07-12-2016), Sapphire Blue (05-06-2020), sklimii (10-31-2014), zjdmm1 (11-10-2014) and 2 others liked this post. (Show less...)
Old 11-02-2014, 03:42 AM
oyster's Avatar
Default Transmission oil.
Oil for the ZF 5HP-24 transmission: VW/Audi part number G 052 162 A2.
Equals ESSO LT 71141. Much cheaper than Jaguar.
The following 8 users liked this post by oyster:
arttomlin (04-04-2015), eszpulecki1 (12-24-2021), GT'thusiast (03-01-2020), hobo (06-10-2019), piper 888 (09-04-2023), Rogerj (07-12-2016), Sir Alex of Yotto (04-17-2016), zjdmm1 (11-10-2014) and 3 others liked this post. (Show less...)
Old 11-08-2014, 04:30 AM
locknlock's Avatar
Pretty good thread, bookedmarked for future reference.
Thanks for the consolidated info
Old 12-28-2014, 12:31 PM
Canuck pump engineer's Avatar
The side marker bulb socket from a 2010 Ford F-250 is an exact replacement for those in my 2003 XK8.
Ford Part Number: F8RZ13K371AA
Here is a link to a source I found for only $7.10 USD:
www.group1autoparts.com/ford/f-250-super-duty/f8rz13k371aa/2010-year/xl-trim/6-4l-v8-diesel-engine/electrical-cat/side-marker-lamps-scat/?part_name=socket-left
The following 9 users liked this post by Canuck pump engineer:
Arland Green (04-20-2021), artntek (05-25-2021), Autobahn kid (01-13-2015), HalBrown (02-03-2021), Hans944 (03-09-2017), K.Westra (07-14-2018), Orthodixie (04-19-2017), scardini1 (01-10-2015), zjdmm1 (03-30-2015) and 4 others liked this post. (Show less...)
Old 01-10-2015, 07:36 AM
larueb's Avatar
Default MAS Sensor - 99 XK8
Remanufactured MAS sensor from NAPA (looks like a OEM with Denso lable removed) part XTP450040. 12 month warranty. $139. Order on line and save $20.
The following 4 users liked this post by larueb:
arttomlin (04-04-2015), Orthodixie (04-19-2017), scardini1 (01-10-2015), sklimii (01-10-2015)
Old 01-15-2015, 01:13 PM
jcb32004's Avatar
FWIW - non-OEM Oil filters for '97-'02 XK8
Mobil 1 - M1-213 (IMHO best - apparently can only get from filtersandwipers.com)
or
Purolator Pure One - PL15317 (IMHO 2nd best)
both ~$10
The following 4 users liked this post by jcb32004:
jimborino (07-07-2017), Orthodixie (04-19-2017), Sir Alex of Yotto (04-17-2016), zjdmm1 (03-30-2015)
Old 01-19-2015, 11:03 AM
brantman's Avatar
Rusty XK8: "left and right idlers"; would that be TIMING CHAIN idlers? Nugs and novices need as much description as they can get! Thanks for the info.
Old 01-26-2015, 11:47 AM
larueb's Avatar
Default Windshield Wiper Blades
My local Jaguar dealer no longer stocks the OEM wiper blades for my '99 XK8, only over the rubber refill. The Bosch Excel plus #41521 is an exact fit and the mountings are correct with no mods. $11.97 at NAPA.
The following 6 users liked this post by larueb:
claudeh (09-14-2020), jgersman (05-17-2017), MrsToadsWildRide (09-09-2016), OA5599 (10-05-2017), Orthodixie (04-19-2017), Rogerj (07-12-2016) and 1 others liked this post. (Show less...)
Old 01-31-2015, 03:12 PM
knightenter's Avatar
Default 2000 xkr conv.
I am having trouble with the "donut" air intake seal #aj86925. They only last about 2-3k miles. The jag part is fraying on the edge and allowinge a vacuum leak. This lites up the restricted
proformance lite and rough running. Any ideas and is there a dupulicate part avail other than jag. This is getting old.
Old 01-31-2015, 03:17 PM
have not seen others with any issues with fraying but SNG Barratt has them available
SNG Barratt - The Ultimate Jaguar Parts Specialist
Quick Reply: XK8/XKR - Non-OEM interchangable Parts Thread
